Old 09-16-2024, 09:54 PM
JLMounce JLMounce is offline
Default Drilling into the Radiator
As the title implies, can this be done? Obviously the end-tanks need to remain intact and sealed to hold pressure.
I'm asking more about the top panel above the tubes and fins. My fan shroud setup has an annoyingly stupid looking strap setup to hold it into place. I'd love to have something much better looking, and using the top cap of the radiator would make that much more functional and better looking.
I've seen people do it and guess the top plate isn't necessarily sealing the fluid, but I've always been worried about it.
I have a cold case, just in case it matters.
What say the experts on this? Can I use some small screws in the top of the radiator for this purpose?
-Jason
1969 Pontiac Firebird
Old 09-16-2024, 11:00 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Pics would help. What is the width and thickness of the top panel. Sorry, not familiar with birds.
The Following User Says Thank You to GtoFM For This Useful Post:
Old 09-16-2024, 11:30 PM
Pictures of the annoyance?
Old 09-16-2024, 11:32 PM
Sirrotica's Avatar
On the old brass radiators often, there was a tin U shaped channel soldered between the tanks for stiffness. If that's what you're talking about I guess 2 holes wouldn't affect the integrity, but you better not be pushing hard when you drill the holes.
I saw a guy doing this with a brand-new radiator on a stock car and drilled right into the core tubes. The guy that owned the race car was less than pleased. Luckily the guy that owned a radiator shop was a friend of mine, and soldered it shut for N/C.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-17-2024, 12:03 AM
Vroom_vroom's Avatar
Vroom_vroom Vroom_vroom is offline
The box on top of the core is hollow. So no fluid in it. However they have the best customer support of any company out there. The tech guys run there products and are happy to talk shop.
77 T/A- poncho 400| T-10|3.23| I beams|Hyper flat top pistons|Kre heads|Scorpion rockers|Xr276 hydro roller|Rpm intake|Smi qjet|Subframe connectors|Rancho sways|Mcleod super street|hydro clutch|More i cant remember
Old 09-17-2024, 09:32 AM
Here’s a picture of the engine bay. You can see the straps that hold the upper fan.
They are just unsightly.
So it sounds like that top u-channel might be okay?
-Jason
Old 09-17-2024, 09:54 AM
78w72 78w72 is offline
Dont they make trim/mounting panels for use with electric fans? Or Ive seen the fans mounted to teh radiator itself without any additional brackets like in your pic... doesnt cold case offer a set up like that? I know other companies have a set up to mount the fans to the radiator without external straps or brackets.
Old 09-17-2024, 10:06 AM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Does the stock shroud not fit or are you using electric fans? Mine is also a Cold Case and you can see where the top panel is only tack welded to the tank it's not a complete weld. I would think you're safe to use a short screw but need to be very careful not to go to far. Less than a 1/2" . I would also remove the stock bracket if you're not using it. You could all so call the manufacturer and see if they can answer for sure.
67 Firebird Convertible
Old 09-17-2024, 10:21 AM
I'm using a Flex-A-Lite fan with an integrated shroud.
-Jason
jwcfbd's Avatar
I just saw this on summit racings website. You can see where this guy ran screws in to the side of the top cap. https://www.summitracing.com/parts/RAD-CHC11
ID:	640095   Click image for larger version
Old 09-17-2024, 10:49 AM
Thanks that's helpful. I'm going to give cold case a ring as suggested.
-Jason
Old 09-17-2024, 10:57 AM
redbird68's Avatar
redbird68 redbird68 is offline
I recently did what you are asking about.
The aftermarket shroud, stock type replacement radiator and fresh engine would not align so I fit the shroud to the fan, then drilled two holes into top of radiator and attached shroud with some very short screws. The top of this particular radiator is a structural brace/shield and is not part of the coolant system. Engine has been broken in and had no issues from this.
ID:	640097   Click image for larger version
ID:	640098   Click image for larger version
birds, goats and a few outliers
Old 09-18-2024, 02:49 PM
I did speak with Cold Case directly and as mentioned here above, you can in fact drill into the U channel which is hollow. So, I'll be doing that.
-Jason
Old 09-20-2024, 05:08 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
I feel like Ive seen Dulchich do it on Roadkill Garage a ton of times, but Ive always had the same anxiety about it you do.
Old 09-20-2024, 07:21 PM
I had a formed plate made for mine, grabbing the tops of the end tanks.
It looks like you could get away with a nice flat plate with cutouts for the latch.
Old 10-04-2024, 06:05 PM
Formula8's Avatar
Formula8 Formula8 is offline
I just drilled into my cold case radiator to mount my electric fans. Kinda's scary to hack up a new $400 radiator but so far no leaks. We will see tomorrow when I drive the car.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
