Old 09-25-2024, 10:22 AM
srmmmm's Avatar
srmmmm srmmmm is offline
If for whatever reason(s), you have the motor out of the car and torn down to the short block, you're not too far away from a Butler 4.25 stroker kit. That gives you 400+ cid with a 4.25 stroke (more torque than a stock 400). That, plus a set of aluminum heads would kick a$$.. Obviously that means a full rebuild, but it would get you pretty much everything you want in a fresh motor that you can have confidence in.
I went the Butler 4.25" stroker kit route with my 350, Comp XE276HR cam with 1.5 roller rockers and 6X-4 heads. Torker-I intake (I know that some think it's a mushy choice, but there's sentiment attached) and 800cfm Quadrajet. CR calculated at 9.3 with Ross flat tops set at 0.0 on the deck. On the dyno, torque was 442 @ 4300 and HP 453 @ 5600. With the add-ons like ignition and Hedman headers, the build was about $9000. With the lighter piston weight of the 350, I think there's plenty of RPM capability to take advantage of the big valve head.
The Following 2 Users Say Thank You to srmmmm For This Useful Post:
