Old 12-31-2016, 08:51 PM
t walgamuth's Avatar
t walgamuth t walgamuth is offline
Originally Posted by carbking View Post
When I first started restoring tripowers, Steve and Chris had not yet started reproducing this stuff, and I had several of these different fittings reproduced (without the Weatherhead markings). Many I made myself (not really that difficult).
Since I no longer have time to restore carbs, probably should take the time to dig out all this stuff and throw it on ebay.
The female inverted flare fittings were challenging, until I found a retired tool and die maker who made me some special taps.
Again, anyone with a hobby lathe and hobby milling machine can make this stuff. To quote an old cliche " it ain't rocket science".
Lots easier today than it once was, thanks to the efforts of guys like Steve and Chris.
Jon.
Thanks Jon!
Tom
Autocrossing, diesel loving, tri-power loving grandpa Architect
  #42
Old 10-02-2024, 05:37 PM
elefantrider's Avatar
elefantrider elefantrider is offline
I'm looking for a big brass block for the vacuum modulator line if anyone has one.
WHile I'm feeling lucky, I also need a '65 kickdown switch mounted to the center carb.
  #43
Old 10-02-2024, 06:08 PM
WHile I'm at it, also need a '65 kickdown switch mounted to the center carb.
Message Dick Boneske, he probably has that brass fitting.
  #44
Old 10-02-2024, 07:54 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
It sounds like you may have a ‘65 Tri-Power with automatic transmission ??
If so post photos as that is a rare breed.
Is this what your inquiring about?
ID:	640857   Click image for larger version
ID:	640858   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
  #45
Old 10-02-2024, 08:32 PM
Yes! I have a couple '65 tripower setups (one is original but missing these components) and I'm wanting to install it on a '65 with AC/PS/PB.
Also need the vacuum kickdown assembly for the center carb.
Did '65 tri-power cars with AC have a high idle actuator for when the AC compressor clutch was engaged?
Also looking for the Calfiornia base aircleaners, and while I'm looking, the 3 flame arrestors too..
  #46
Old 12-24-2024, 02:50 PM
Joe37 Joe37 is offline
Here are some pictures of a '65 Catalina setup. Automatic T400 pulls vacuum from the brake booster fitting just as shown above. The " T " fitting on center carb is distributor to drivers side, HVAC to passenger side. I threw in a couple lockdown switch pictures.
Joe
ID:	645174   Click image for larger version
ID:	645175   Click image for larger version
ID:	645176   Click image for larger version
ID:	645177   Click image for larger version
  #47
Old 01-12-2025, 05:39 AM
Thanks for the detailed pics. Looks very good. Would GTOs with AC/PS have had the same Tri-power setup as the big cars?
  #48
Old 01-19-2025, 11:29 AM
Yes, the GTO used the same setup only mechanical linkage, '65-'66 only. '66 had a bigger center cab and matching manifold. Nothing wrong with vacuum system if its working correctly, you just have to remember that they are slower to release than mechanical linkage ( have plenty of room ahead of you ).
The Following User Says Thank You to Joe37 For This Useful Post:
  #49
Old 01-19-2025, 04:22 PM
60sstuff's Avatar
Trust me, I know all about that SLOW release of WOT.
ID:	646384   Click image for larger version
