Old 10-15-2024, 08:51 PM
slowbird's Avatar
slowbird slowbird is offline
Default Ported Victor vs ported NorthWind dyno test
We tested the Victor vs the NorthWind today. Both portedby same guy (Johnny from CFM South), both ran the same 2" tapered spacer and same carb.
I was somewhat surprised by the results.
Intake is written on top of sheets
ID:	641295   Click image for larger version
The Following 3 Users Say Thank You to slowbird For This Useful Post:
Old 10-15-2024, 10:48 PM
R 70 Judge's Avatar
Cool test! When you factor in that the northwind is 1.2” shorter than the Victor it is actually impressive it nearly kept up. I appreciate you putting in the effort for back to back testing.
James
1970 Trans Am
Old 10-15-2024, 10:49 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Excellent test Slowbird.... Thanks for sharing the results
Go fast, see Elvis!
Old 10-16-2024, 07:44 AM
chuckies76ta's Avatar
Thanks for posting.
950 Quickfuel.
Old 10-16-2024, 09:28 AM
Thanks for sharing. It would be interesting to see what the difference would be no spacer as the NW being lower seems to be tighter into the ports and might be uses for those with hood clearance issues without spacers..
Old 10-16-2024, 11:27 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
^^^ about what Chuck at Butler told me about my TA. Given hood clearance issues the Northwind WILL fit under the shaker and only give up a little bit vs the Victor. We are putting together a top- end package for my 455 and it MUST stay under the shaker Thanks for the data Slow bird!
Old 10-16-2024, 01:28 PM
Not sure how it is going to fit a Shaker unless it is on the hood. My 78 a T2 barely fits!
Old 10-16-2024, 02:41 PM
Pretty sure you will need to do what Dave this to this 4150 intake. Intake on left is N.W versus Victor
950 Quickfuel.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 10-16-2024, 08:00 PM
pictures on Facebook look like you took out the cloverleaf to a mainly square opening.
Old 10-17-2024, 03:09 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Thanks for the info, I am going to the northwind this winter on my setup, been running the victor with no spacer and can just barely keep my flat hood with foam glued to the front of the air cleaner lid where it makes contact.
Old 10-17-2024, 03:17 PM
steve25 steve25 is online now
Your BSFC numbers are scary on the lean side to me.
All too often well below .400.
Old 10-17-2024, 03:47 PM
Steve C. Steve C. is offline
A tip bit that could be of interest to some, and somewhat related......
On the Year One Bandit Trans Am project with a 535 combo Jim Butler used a Victor intake with the carb flange milled down 0.650" to help it fit under the hood.
With the cut down intake he used a WFO drop base unit for the TA Shaker scoop. Tested on the engine dyno at peak power rpm it gave up about 15 hp by milling the intake.
On my current 505 engine prior to the direct port fuel injection conversion I did the same thing with a Victor intake & HP950 carb using no carb spacer.
On the engine dyno I lost about 8-10 hp at peak power rpm after milling the intake flange 0.650".
My application is street only therefore I did not miss the 8-10 hp.
Old information here:
Old 10-21-2024, 01:48 AM
lust4speed's Avatar
Just to help me out visualize the height, how does the North Wind without a spacer compare to the height of a Performer RPM? They seem like they are around the same height?
Mick Batson
Old 10-21-2024, 07:06 AM
https://www.tinindianperformance.com...-measurements/
950 Quickfuel.
Old 10-21-2024, 08:53 AM
Stan Weiss's Avatar
Steve,
BSFC numbers an indicator of efficiency, and not an indicator of air fuel ratio.
Stan
Pontiac Pump Gas List
Old 10-30-2024, 09:25 PM
joes455 joes455 is offline
The NW would shine using a dominator flange
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 10-30-2024, 11:28 PM
slowbird's Avatar
It has a dominator flange in this test
Old 10-31-2024, 08:57 PM
Matt1970gto Matt1970gto is offline
You still a foot braking fool?
