I just picked up these 3.07 gears to swap out my 3.73’s for a more friendly rpm range.
Can someone look at these pics and tell me what you think? I picked them up for $150 as they were listed in “great condition”. Thanks, Don
1966 GTO 1966 421-10.1-1 comp-Race Tec 23cc Pistons KRE Tri-Power KRE 65cc Aluminum Heads XE274 cam by Comp Cams DUR 230 Int 236 Exh @.050 - 110 LSA LIFT .491" Int .491" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
I dont see anything disqualifying i will just say its measurably harder to set up used gears not knowing previous backlash but doable
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
| The Following 3 Users Say Thank You to Formulas For This Useful Post: | ||
Does the "2" represent pinion depth variance? If not, getting pinion depth right will be a guessing game, which is going to make getting the mesh correct even more difficult. |
I haven’t a clue about the 2 stamped on the pinion.
Photo #2 looks like the ring gear teeth are galled but I don't see corresponding look on the pinion teeth. Are those teeth as rough textured and pitted as the picture makes them look?
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Here is a different section of the ring gear and a pic of the backside of the pinion.
1966 GTO 1966 421-10.1-1 comp-Race Tec 23cc Pistons KRE Tri-Power KRE 65cc Aluminum Heads XE274 cam by Comp Cams DUR 230 Int 236 Exh @.050 - 110 LSA LIFT .491" Int .491" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears Last edited by SD421; 11-08-2024 at 04:10 AM. Reason: Different pic needed |
What the hell are all the punch marks on the face of that gear?
The pinion depth is designated by a 2-digit code for that 12-bolt ranging from 40 to 50. A 45 designates a specific depth (can't remember what it is, have it written down) and numbers below subtract 0.001" per increment and digits above add 0.001" per increment. It can be stamped into the tip of the yoke end. I just checked a 3.07 12-bolt pinion and it is written (grease paint?) on the face of the gear on the bearing side and is a "45".
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
| The Following 3 Users Say Thank You to AG For This Useful Post: | ||
If it's anything like the similar marks on my Lumina camshafts, it's how they hold the part securely when performing the machining operation(s).
| The Following 3 Users Say Thank You to Schurkey For This Useful Post: | ||
Not impressed with the tooth face surface in photo#2. The wear pattern is even and covers most of the face indicating proper pinion depth setting, but the pitted surface tells me there were fluid issues from heat, contamination or probably dirt. The 2.73 that just came out of my rear end after 164,000 miles had same wear pattern, but the tooth faces had a polished finish to them.
My opinion: the gears can be used, but may be a bit noisy. They are not 'junk'. You may not even hear them over the exhaust being dumped out of your Tribal Tubes from that tripower 421 you're packing.
Jeff |
| The Following User Says Thank You to geeteeohguy For This Useful Post: | ||
| The Following User Says Thank You to SD421 For This Useful Post: | ||
Buff that light rust with 400 grit.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
In your third pic where it focuses on the snout of the pinion is where it is supposed to be stamped. If you look straight down onto the face of the gear below the gear is where mine is marked "45". I also have a 2.56 pinion from 1972 and I'll check that one to see where the number is.
| The Following User Says Thank You to AG For This Useful Post: | ||
I respectfully disagree. Maybe some 0000 steel wool at most. Never use sandpaper or emery cloth on a gear surface. At least I wouldn't.
Jeff |
My first impression is the gears were media blasted to hide defects.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
| The Following User Says Thank You to KEN CROCIE For This Useful Post: | ||
Yep. Took out the rust and left the pockets.
| The Following User Says Thank You to lust4speed For This Useful Post: | ||
Definitely media blasted to hide defects.
Looks like the ring gear is still dusted with blasting media. No set of used gears should like like those ones pictured.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
IMO, they will work but they will probably be noisy. I don't like ANYTHING bead blasted. I've seen more ruined carbs, engine cases, valve covers, you name it. Once it gets 'frosted' there's no going back.
Jeff |
