Old 11-15-2024, 03:54 PM
Default Help identify under dash wiring
This is from under the dash of a 69 GTO we are working on. Can anyone tell what it’s for the one end looks like the plug has rotted apart. Thanks
ID:	642835   Click image for larger version
ID:	642836   Click image for larger version
ID:	642837   Click image for larger version
Old 11-15-2024, 05:20 PM
tom s tom s is offline
I think the purple is neutral safety.Tom
Old 11-15-2024, 05:25 PM
Was this a manual with cruise control? This could be a jumper harness for that app IF offered by the factory.
Old 11-15-2024, 05:53 PM
OG68 OG68 is offline
Rear Defogger.
The other harness half will be under the drivers seat. Brown wire with red connector is accessory power, Purple wire is high speed blower, white wire is the resistance wire for low speed. The resistance section is in the other half of the harness.
The Following 3 Users Say Thank You to OG68 For This Useful Post:
Old 11-15-2024, 07:31 PM
Rear Defogger.
Thank you it’s my buddy’s 69 judge I have a copy of his phs here sure enough it had rear defogger on it. Thanks again.
The Following User Says Thank You to grandam1979 For This Useful Post:
