So now that we've determined the carpet color, we're looking to put carpet in my son's 65 Tempest crew cab. I see that a couple of places offer 4 door carpet, but they say auto only. My son's car has a floor shifted 3 speed. I contacted one place, and they said they don't make 4 door carpet for floor shift manual. I asked if I could buy the front piece for a 2 door 4 speed, and the back piece for a 4 door, but they said they can't separate kits. They suggested I buy 2 sets of carpet and just use what I need. Not a useful option for a 17 year old on a taco bell salary.
So....I have no doubt that the front carpet for a 2 door will fit his 4 door. I'm thinking we could just buy 2 door carpet and it should be wide enough to go under the rear door sills? It's been a while since I put carpet in one of these cars; aren't they usually cut longer/wider and you have to trim them to fit? Has anyone tried this? Thanks, Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am |
There's usually a few inches of overlap between the front and rear carpet you might get away with.
I wonder how a B body carpet would fit
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
There appears to be a fair bit of difference between the rear section for a 2 dr and rear section for a 4 door Lemans or Tempest. Does the three speed have a shift porch on the floor ? If no then go with the 4 door. If yes and you go with the 2 dr for m/t you may need an extra 1/2 yard of material to piece in at the rear. Check the images on ACC's web site, drill down by year, make, model and # of doors and transmission for an image of each.
what color i have a brand new parchment (goldish) one in the box
Just buy a kit for floor shift 2 door. The rear floor pan is not different 4 dr. vs. 2 dr.
You are correct; the floor pan is the same, but the carpet is different because the lower part of the back seat is different. We ended up buying carpet for a 2 door, but we had to buy extra material to cover a small patch on each side of the back seat by the back doors. My son is happy with it.
| The Following User Says Thank You to importsmasher For This Useful Post: | ||
