Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-26-2024, 04:07 PM
XLR8STEVE's Avatar
XLR8STEVE XLR8STEVE is offline
Default 68-72 A body Rear end and suspension parts - NW Detroit area
Hello Pontiac friends. I have some good parts for sale. Changed over to 9".
-12 Bolt Rear from a Chevelle. Stock width. 3.73 thin gear, 4 series carrier, 33 spline Truetrac, welded tubes, solid spacer, 3" 1/2" moser studs, billet yoke 1350, Big ford ends welded by DTS (no c clips) with big drum brakes. Just rebuilt by DTS. Original build and rebuild POs attached. $2,900.00
-UMI Control Arm Braces 4028-B. new 160.00 - $80
-BMR Extreme Anti Roll Bar XSB006H new 500.00 - $300.00
-TRZ adj upper control arms new 229.00 - $125
-UMI lower control arm relocation brackets 4012-B new 150.00 - $75.00
-Dick Miller NO HOP bars the 12 bolt has had these installed - $200.00
-Drive shaft CCI 3.5" DOM steel. Billet yoke 1350s. Was in a 70GTO with a Tremec Magnum 6 speed and the 12 bolt. new 450.00 - $150.00
I can ship smaller items for ups cost.
ID:	645239   Click image for larger version
ID:	645240   Click image for larger version
ID:	645241   Click image for larger version
ID:	645242   Click image for larger version
[SIGPIC]
Steve
Old 12-26-2024, 04:09 PM
XLR8STEVE's Avatar
Default pics
pics
ID:	645244   Click image for larger version
ID:	645245   Click image for larger version
ID:	645246   Click image for larger version
ID:	645247   Click image for larger version
[SIGPIC]
Steve
Old 12-26-2024, 04:10 PM
XLR8STEVE's Avatar
Default pics2
pics2
ID:	645249   Click image for larger version
ID:	645250   Click image for larger version
ID:	645251   Click image for larger version
ID:	645252   Click image for larger version
[SIGPIC]
Steve
Old 12-26-2024, 04:11 PM
XLR8STEVE's Avatar
Default pics3
pics3
ID:	645254   Click image for larger version
ID:	645255   Click image for larger version
ID:	645256   Click image for larger version
ID:	645257   Click image for larger version
[SIGPIC]
Steve
Old 12-28-2024, 08:23 PM
grivera's Avatar
grivera grivera is offline
What is the part number on the adjustable upper control arms - may need a set for my 66 Lemans and want to know if compatible
Will Rivera
Old 12-29-2024, 10:11 AM
XLR8STEVE's Avatar
The TRZ arms are 317-201-2. Only 68-72. There is another part # for 64-67
[SIGPIC]
Steve
The Following User Says Thank You to XLR8STEVE For This Useful Post:
Old 12-30-2024, 12:37 AM
jspeed's Avatar
jspeed jspeed is offline
Default brackets, 12- bolt
Hey Steve, on your 12-bolt what's the , measurement between the backing plates, also interested in your TRZ upper control arms and lower relocating brackets.. PM sent
Old 12-30-2024, 01:45 AM
jspeed's Avatar
Default driveshaft
interested in the drive shaft also.
Old 12-31-2024, 12:02 AM
CatalinaMike CatalinaMike is offline
What is the length of the driveshaft? Thanks
Old 12-31-2024, 11:12 AM
XLR8STEVE's Avatar
Driveshaft trz uppers and lower relocation brackets sold.
Still have 12 bolt , bmr anti roll bar, no hop bars and braces.
[SIGPIC]
Steve
Old 01-09-2025, 04:04 PM
XLR8STEVE's Avatar
[SIGPIC]
Steve
Old 03-11-2025, 11:23 AM
XLR8STEVE's Avatar
Bump - Rear now $2700. Also have the other parts from last reply.
[SIGPIC]
Steve
Old 04-22-2025, 09:08 AM
XLR8STEVE's Avatar
Bumping. Make a reasonable offer on the 12 bolt via PM. Still have other suspension parts below.
[SIGPIC]
Steve
Old 05-29-2025, 10:52 AM
XLR8STEVE's Avatar
bump...rear end, no hop bars, stiffeners, trz upper spherical joints available.
[SIGPIC]
Steve
Old 05-30-2025, 07:39 PM
VCho455's Avatar
VCho455 VCho455 is offline
PM sent.
