Originally Posted by Formulajones
When you say you updated to 2.0 are you talking about just a software update or did you replace the entire unit?
If the entire unit was replaced then as mentioned you may have to go through the whole IAC adjustment deal, but first I'd go in to the touch screen, as mentioned, and command the idle rpm you want. It's just a few simple clicks of the touch screen.
Replaced the entire unit.
