Old 01-06-2025, 02:15 PM
67drake's Avatar
67drake 67drake is offline
Default Anti seize on glow plug threads?
I need to replace a glow plug on my Duramax after work today. These threads on the plug are kinda weenie. I was considering putting a dab of anti seize on the threads of the new one, but worried it might affect its performance because it wouldn’t ground well?
Any ideas pro or con?
‘55 Catalina
Old 01-06-2025, 07:22 PM
Trulyvintage's Avatar
Trulyvintage Trulyvintage is offline
Lightbulb Nope
Before you remove the glow plug spray brake cleaner and blow any residue out of the glow
plug depression - if the female threads require cleaning, you can use a fine wire brush with a taper and then make sure you vacuum out the cylinder before you put the new glow plug in.
Lubricant is not required - just snug up
the plug & then back out and tighten
carefully - I replace all the glow plugs
when I service my diesel.
Jim
The Following User Says Thank You to Trulyvintage For This Useful Post:
Old 01-06-2025, 07:28 PM
Sirrotica's Avatar
By all means put it on, any diesel glow plugs should have it on. If you've never broken one off a glow plug in a cylinder head, believe me, you don't want to. The thin metal shell is prone to twist off when the threads freeze into the heads. When they break off you're likely pulling the head to remove it. The cylinder heads are cast iron so you need something to help with the galvanic corrosion.
I use never seize after cleaning the body grounds to keep the connections from becoming corroded in the salt bath environment we have in Ohio, it works fine. I also use it on spark plug threads, and on the glow plugs in my diesel trucks.
There are 2 types of never seize, one uses aluminum, and one uses copper, they both will conduct electric, but copper is slightly better.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 4 Users Say Thank You to Sirrotica For This Useful Post:
Old 01-06-2025, 08:11 PM
67drake's Avatar
Thanks guys.
I put some on. After I posted this my diesel mechanic son got back to me. He said he puts anti seize on when he replaces them too.
All done BTW
I was getting an error on the #6 cylinder and the code said glow plug. I’ll find out in the morning if it’s working!
ID:	645777   Click image for larger version
‘55 Catalina
Old 01-06-2025, 08:13 PM
Bills Auto Works's Avatar
Bills Auto Works Bills Auto Works is offline
Yes Definitely put never seize on your glow plug threads.
As someone who has actually done them from time to time....You never want one to break off, because it is a bitch to get the broken piece out
God Bless
Bill
https://www.jalopyjournal.com/forum/...closed.614419/
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society"
Your QUALITY Pontiac Transporter Since '83
1955 Chevy Alt. W.B. Gasser
1955 Nash Ambassador Cust Lemans
1957 T-Bird
1964 Grand Prix
1966 Catalina Conv
1966 Ambassador DPL 2dr
1966 Ambassador Cust. 2 DR
1967 Marlin
1967 Toro
1973 Nova Chassis Car
1992 Jag XJS Conv
1992 Jag XJS Coupe
2007 Cad XLR-V Supercharged Roadster
2008 Avalanche Southern Comfort Edition
The Following User Says Thank You to Bills Auto Works For This Useful Post:
Old 01-06-2025, 08:16 PM
Originally Posted by 67drake View Post
Thanks guys.
All done BTW
Typing at the same time LOL
Glad you were successful !!
God Bless
Bill
1957 T-Bird
1964 Grand Prix
1966 Catalina Conv
1967 Marlin
1967 Toro
1992 Jag XJS Conv
1992 Jag XJS Coupe
Old 01-06-2025, 10:09 PM
limejudge69's Avatar
There are actually 4 types of anti-sieze: Copper, Aluminum, Moly and Nickel. They all have their specific recommended usage. Aviation uses nickel a lot due to the high temps and stainless/exotic alloys
The Following User Says Thank You to limejudge69 For This Useful Post:
Old 01-06-2025, 11:59 PM
Sirrotica's Avatar
Maybe I should have said automotive never seize, the others aren't common in automotive usage. You won't find them in a parts store or in one of our garages. Thanks for keeping the record straight..........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 2 Users Say Thank You to Sirrotica For This Useful Post:
