Old 01-06-2025, 08:10 PM
MO Olds MO Olds is offline
Default Code 11 Cameo White
Hi - I have a '79 in Cameo white, Code 11. Was wondering for those with a Cameo white car around that timeframe, can you describe it? My car has been painted I know for sure and it looks like a "bright white". Maybe they used a Corvette paint shade which should be different since they're two different codes.
Recently had a quart mixed for code 11 and it came out slightly off white, almost a pearl but without the metallic in it. Wondering which is more factory correct? Obviously hard to do a Google search as computer screens change colors and hoping for first hand experience. Thanks in advance for any opinions!
Old 01-06-2025, 09:19 PM
Torquewar's Avatar
Torquewar Torquewar is offline
Hello I have a code 11 78 TA. My car is approx 70% original paint. The white is definitely bright to me . I had to fix some lower door damage etc and I also decided to do the firewall yrs ago. The mix I got was spot on. There’s definitely no pearl look to it. The mix u have as described is probably off. A very good body guy I know cringes at trying to match white paint. It takes a trained eye to get it right.
Old 01-06-2025, 09:40 PM
Interesting. I heard/read black is hard to match but makes sense for white given the trouble I am having. I will try to post a pic too. The hood and fender are just a tinge off. Like you said wonder if was also a formula thing since the computer to find the color couldn't go back too far
Old 01-06-2025, 09:51 PM
Torquewar's Avatar
Question did u have a part scanned , .The technology is amazing but not always 100% . You are correct on going back to records 40-50 yrs ago . The brand of paint can affect the shade etc. I actually remove a spoiler end cap and from there the paint was mixed . Ironically it was a younger lady who did it . She was well known to have a great eye and get the formulas down.
Old 01-06-2025, 11:39 PM
Elarson's Avatar
Elarson Elarson is offline
I used to have a '77 T/A Cameo white. It is not bright white. Hard to describe.... maybe it has just a faint whiff of brown?? I didn't realize it wasn't bright white until I parked it next to a '70 T/A
Eric
Old 01-07-2025, 12:09 PM
I didn't, just provided the code and year. What's making it harder, car was repainted 30 years ago, had a small engine fire, hood repainted a year after repaint and hood doesn't match the car. The quart I got matches the hood but not rest of the car..
Old 01-07-2025, 12:11 PM
Eric
Yes- that is a way better description than mine. It is a nice clean white but a shade off.
Old 01-16-2025, 10:39 AM
Warren Seale Warren Seale is offline
I have a 79 Cameo White T/A. When this is next to my 13 Bright White Vette, you can see that the Cameo White is a cream color. I would say that the Bright White is pure white whilst the Cameo is an off white.
The body is still all single stage lacquer with about 80% being from the factory. All of the soft rubber parts like the bumper and spoilers have been painted with modern single stage urethane that holds up better with flexible parts compared to lacquer that tends to crack over time. The urethane paint appears to be a little brighter when viewed with certain lighting. I don't know if it is due to the different base material or if the tinting is a bit off. I have observed that new cars with the factory paint and urethane bumpers also tend to be a little different compared to the neighboring body panels.
79 T/A,WS6,403,A3
96 T/A,WS6 (#1344) ,M6
72 442,W30,A3
96 Vette convertible Grand Sport (#713),F45,M6
13 Vette 427 convertible (#1425),Z30/Z25,M6
Old 02-02-2025, 10:50 PM
Apologies for the delayed reply. This was the kind of answer I was hoping for - a comparison side by side to another GM white / corvette. I plan to do a single state in the future and will keep it that in mind. Even now, mine is the same way where the soft parts (bumpers, spoilers, wind dams, etc) are a different shade because of the base material. Thanks again for sharing this, a big help.
Old 02-02-2025, 10:54 PM
I think the problem is solved and thanks to all those that chimed in. Warren Seale summarized perfectly. Below is what I have currently; not the greatest lighting but its more noticeable in person. You can tell the hood (Cameo White 11) is a shade off from the fender. Based on what everyone is saying, the hood is the 'original' shade of white and the fender is probably Corvette white.
Name:	Cameo White Shade.jpg
