Old 01-08-2025, 05:11 PM
CGMDD CGMDD is offline
Default WTB 72 Front Speaker Wire
I'm looking for the wire and connector that connect to the front speaker wire. It appears that the end of the connector is plugged into by the power connector?
Old 01-08-2025, 07:19 PM
OG68 OG68 is offline
Factory AM radio?
Old 01-08-2025, 07:20 PM
It is a factory AM
Old 01-08-2025, 07:25 PM
Does the speaker currently have a single green/blk wire or two wires, green/black and black? Or no wires at all?
Old 01-08-2025, 07:29 PM
Right now it's just a single green coming off of it. The previous owner kind of hacked up the wiring
Old 01-08-2025, 07:35 PM
From the 72 service manual. Which part do you need? The Connector?
Old 01-08-2025, 07:40 PM
Yeah I need the speaker connector with the wire that runs to the speaker. I have the one that runs to the instrument wiring harness.
Old 01-08-2025, 07:45 PM
I'll take a look in my stash. I'll get back to you.
Old 01-08-2025, 08:47 PM
Held for Ransom's Avatar
I already had the connector for my radio, but you can find them on eBay.
https://www.ebay.com/itm/395374874354
My low mileage Formula had a bad speaker and I had replaced it. I had to make my own wire by using 24" of 18 AWG wire and a Packard 56 female terminal.
ID:	645879   Click image for larger version
So long, farewell.
Old 01-09-2025, 03:28 PM
I don't have the correct plug. IIRC 69-72 A body radios had a different plug. not shared with Firebird or B bodies.
Here is another ebay source. You can contact him for what you are looking for.
https://www.ebay.com/itm/25543275836...wAAOSwf49iLQhj
You can also contact Scott Thelander. He may have the correct plug and is a member here.
