Old 01-10-2025, 06:12 PM
John Milner's Avatar
John Milner John Milner is online now
Default TH400 late shifting to 3rd
I have a th400 that is late shifting to 3rd gear under normal driving conditions. The 1st to 2nd shift is perfectly normal. Driving around town at 30 mph it will just stay in 2nd. If I wind it up to about 40 mph, it will finally shift to 3rd. The vacuum lines on the modulator line are in good shape. To my knowledge, the transmission has never been rebuilt. Does anyone know what might be causing this 3rd gear shifting issue? Thanks
Old 01-10-2025, 07:30 PM
Governor weights stuck….
Kick down switch or adjustment….
Modulator, modulator valve sticking…
Weak vacuum signal….
Old 01-10-2025, 08:04 PM
I don’t know about the modulator being a cause.
Whenever one of was bad or not hooked up the trans would not shift out of 1st.
Old 01-10-2025, 08:39 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
My brief tenure at an AAMCO shop taught me one thing…an automatic acting funny like that, without an immediately identifiable issue - low fluid, vacuum line not hooked up, etc., usually means internal problems.
I’m dumb as to the inner workings, the governor being stuck may be it, if so should be easy to diagnose/cure.
costs too much
Old 01-11-2025, 02:30 AM
Schurkey Schurkey is offline
...sticking valve in valve body
Old 01-11-2025, 04:25 AM
Kenth's Avatar
Kenth Kenth is offline
Check this:
Name:	TH400 late 2-3.JPG
ID:	646007   Click image for larger version
Name:	TH400 diagnosis.JPG
ID:	646008   Click image for larger version
Name:	TH400 oil pressure.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-11-2025, 09:21 AM
Low fluid level or clogged filter are usual suspects from my view. Then Post 2 kicks-in.
Old 01-11-2025, 09:30 AM
All my auto transmissions that are controlled with a vacuum modulator do that when I'm up at high elevations. Low vacuum signal to the vacuum modulator will cause a delayed shift, most noticeable on the 2-3. As soon as I drive back down to sea level it's back to normal.
Not sure what elevation you're dealing with but it's something to look at. Could just be a simple adjustment on the vacuum modulator (screw inside vacuum nipple) If someone was messing with yours there is no telling what they might have set it at.
When I adjust mine down to shift normally at high elevation, it causes very quick short shifts when I'm at sea level, so it's a balancing act. I just have to live with it one way or the other or find a happy middle spot that's good enough.
https://youtu.be/XqEydRRRwqE
Old 01-12-2025, 02:50 AM
What is hilarious is that the huge, black-canister modulator assembly that everyone tosses in the trash in order to install a crappy, cheap aftermarket "adjustable" modulator...is altitude compensated. They're also adjustable in most cases, provided you're careful about breaking the spot-weld on the adjustment screw.
Old 01-12-2025, 03:48 PM
Yup those things are almost non existent anymore.
Old 01-12-2025, 05:01 PM
Squidward's Avatar
I had similar symptoms on a th400 years ago. Cause was a bad governor flyweight pin, the ones that hinge the weights and look like crimped panel nails. New governor fixed it. $20 and a gasket at AAMCO's parts counter.
