Old 01-17-2025, 03:22 PM
Domarinolo Domarinolo is offline
Default 1966 GTO ignition switch question
Brand new member here, currently enjoying a frame off restore of a 66 GTO in my garage. Used AAW classic update kit and it went fairly well for a rookie. But the OEM ignition switch has a terminal labeled "Ign.2" which the AAW kit does not replicate. Original wiring was gone when I started so I couldn't trace it. Anyone know where the Ign. 2 lead went or it's purpose? Thank you!
Old 01-17-2025, 03:42 PM
IGN-2 goes to coil (+) for full battery volts while cranking.
Clay
Old 01-17-2025, 04:46 PM
Kenth's Avatar
Kenth Kenth is offline
If the AAW kit do not have the yellow IGN 2 wire you may, if your starter has a "R" terminal, connect a yellow wire from there to the + on ignition coil for the same purpose.
Name:	Starter circuit.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-19-2025, 08:11 PM
GT182's Avatar
GT182 GT182 is offline
Domarinolo, if you don't have it back together and want the parking lights on with the headlights, do this.
Take the purple wire off of Tab 7 it's on and move it to the front left side of the of the switch to Tab 3. That's the taillight tab and both will be on together. The front end looks a lot better at night with both on. And it's safer too with them both on. The law changed in '68 to have both on together.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
The Following 2 Users Say Thank You to GT182 For This Useful Post:
Old 02-20-2025, 07:39 PM
ZeGermanHam's Avatar
FYI, the American Autowire Classic Update kit is already configured to run the headlights and parking lights simultaneously when they ship it. No need to make any changes if that's the goal. I used the AAW Classic Update kit in my '66, and made no changes to how they configured it.
1998 BMW 328is (track rat)
