Old 01-21-2025, 06:05 PM
I think the only difference between the 73-76 & 77-81 base plate is the trailing edge, and you can trim that off an make it work, but not sure. I think it is the later one I got, if need be, I can measure and take pics for you to compare?
https://www.firebirdcentral.com/1977...p/she-2580.htm
  #202
Old 01-21-2025, 06:10 PM
I see a used original on eGay, but not sure what year it is:
https://www.ebay.com/itm/38772955826...yABEgJo7_D_BwE
  #203
Old 01-21-2025, 07:51 PM
72projectbird's Avatar
On the welting, any recommendation on the type of adhesive to use?
I've used a bunch of different stuff. Weather stripping adhesive seems to work well, but I've used regular super glue in small amounts. I've even used just random adhesive I had laying around.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #204
Old 01-24-2025, 04:29 PM
Some more misc bodywork and panel alignment pics.
1987 Grand National
The Following 3 Users Say Thank You to 72projectbird For This Useful Post:
  #205
Old 01-24-2025, 05:40 PM
Formulabruce's Avatar
Looks like Mitch is on a mission! Looks great!
" Long may we DRIVE !"
  #206
Old 01-31-2025, 04:32 PM
First round of primer taking place! Next up will be the sandblasting and detailing of the subframe, suspension, rear axle and leafs. Also going to take apart the trans and get it vapor honed to bring back the raw aluminum look.
1987 Grand National
  #207
Old 01-31-2025, 05:00 PM
grd777 grd777 is offline
Smile
this is fun to watch ,keep them coming. When people want to buy a restored car and do not know how many hours goes into something like this think we are crazy when we sell the car
  #208
Old 02-22-2025, 11:03 AM
Anyone have the pulley part numbers for 70 Trans Am with air-conditioning
  #209
Old 02-22-2025, 01:02 PM
Water pump..
Ps.
ID:	647857   Click image for larger version
  #210
Old 02-22-2025, 03:08 PM
Crank 480507? W/ sep pulley ?
  #211
Old 02-22-2025, 07:01 PM
I will take it off tonight and get #s
  #212
Old 02-22-2025, 07:59 PM
Held for Ransom's Avatar
Here was my info. The only difference is my upper pulley was stamped with another number.
https://forums.maxperformanceinc.com...d.php?t=392985
So long, farewell.
  #213
Old 02-22-2025, 08:45 PM
Lower pulleys. FYI.. the Stock belts fit perfect.
ID:	647886   Click image for larger version
ID:	647887   Click image for larger version
  #214
Old 02-22-2025, 10:07 PM
Ryan/ Dave.. I am not sure if Mitch knows, but the Sides of the cowl, lower " A" pillar ( hinge area) AND the front air horn side area are BOTH painted car color on our cars.
  #215
Old 03-07-2025, 05:55 PM
Things are happening:
1987 Grand National
The Following 2 Users Say Thank You to 72projectbird For This Useful Post:
  #216
Old 03-07-2025, 06:13 PM
Better get that left leg excercised!! I see some clutch activity this summer!!
  #217
Old 03-07-2025, 08:18 PM
That be nice!
Ordered the date coded glass today. I need to get the dash out to get restored, same with the gauge bezel. Also need to figure out what to do with the steering wheel.
1987 Grand National
  #218
Old 03-09-2025, 03:06 PM
Subframe stripped, blasted and body worked along with the rest of the front suspension. Same deal with the rear. Up next is the disassembly of the 12 bolt, which will get the same treatment.
1987 Grand National
  #219
Old 03-12-2025, 01:24 PM
So I need front springs. I have one original from the car, but unfortunately the other was broken. The good one I have still has the original tag on it. I can't read the part number, but it looks like it says FM in big letters, and the tag looks like it was blue at one time.
Any advice on replacement springs? I've screwed with a bunch on other TAs, and I always end up having to trim them to get the car to sit right.
1987 Grand National
  #220
Old 03-12-2025, 03:31 PM
If you'll use new, the Eaton with the 1 inch drop seem like the right height. I would NOT get the highest spring rating either. Keep in mind these cars ALL sat " about " and inch higher in the front in Stock form due to weight in front.
Never get generic springs for 67-81 camaro nova big block.
