Old 02-21-2025, 01:57 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
This is how to slow a blower down to 19% of crank speed!
The Following 3 Users Say Thank You to Jack Gifford For This Useful Post:
  #42
Old 02-22-2025, 12:51 PM
GTO-relic GTO-relic is offline
it's going to be seriously out of balance with the torsional loads only on far ends of the block.
take a regular Pontiac V8, pull the middle 4 spark plug wires, start it up.
or better yet, take the old Pontiac 4 cylinder half v8 engine, pull the middle spark plug wires,
start it up.
those ran wobbly rough as schit even with all 4 cylinders firing brand new,
like they had a constant miss.
that's how it's gonna run.
the drive shaft connection is like going to hell to light a match,
why not just put a regular crank in, and remove all the pistons/rods you don't want to use ?
you're reinventing the wheel but making it square to see how it rolls
yes you can sit on a rocket, light it, and go really fast like the cartoon Coyote
would you really want to do it though ?
it's a great thread attention getter, but that is engineering silliness.
there's an old saying, you can't make chicken salad out of chicken schit...
and you can only polish a turd so much...
no offense intended, just being honest.
sure it will make HP. I can put a blower on a Yugo 4 cyl it'll make tons of power too.
why bother ? build a real V8 hemi with those heads dude !
  #43
Old 02-22-2025, 01:24 PM
tom s tom s is offline
Jack has been building and RACING Pontiac Hemis for years!He has nothing to prove with a V8 or even a 4 cyc Hemi!Tom
The Following 3 Users Say Thank You to tom s For This Useful Post:
  #44
Old 02-22-2025, 01:27 PM
misterp266's Avatar
“it's a great thread attention getter, but that is engineering silliness.
no offense intended, just being honest.”
Nice work good Jack. Your engineering silliness is outstanding! Looking forward to hearing how it runs. Mickey would love it!
" Darksiders Rule "
  #45
Old 02-23-2025, 01:26 AM
... Looking forward to hearing how it runs...
So am I.
I don't know about producing power, but I'm guessing it will SOUND even nastier than the four did. CR is up to 12.8:1 (from 12.4), and cranking compression is 180 and 170 PSI prior to break-in (was in the 150's for the four).
The Following User Says Thank You to Jack Gifford For This Useful Post:
  #46
Old 04-24-2025, 12:30 AM
Finally got a good test run of the twin today. The tune is close enough to see A/F ratios in the ballpark- 4.8 to 5.4 with a throttle hit. No unusual vibration or shaking. So I'll start re-installing it, shooting for the July event in Loring.
Strange- how the exhaust doesn't sound like a twin, just sounds mean like the four did! And totally unlike my odd-firing John Deere.
  #47
Old 04-24-2025, 05:19 AM
Very good to hear Jack!
I hope all goes superb for you.
  #48
Old 04-24-2025, 07:38 AM
Scott Stoneburg's Avatar
Glad to hear it's running, looking forward to seeing/hearing any videos of it. Nice job!
  #49
Old 04-24-2025, 08:39 AM
mgarblik mgarblik is offline
Great to hear it's running once again! Pics and/or video please. Like keeping up with your progress.
  #50
Old 05-03-2025, 01:07 AM
I had always installed just the long block into the lakester, then did the cramming of all else. With the engine/drivetrain assembled from the test run, I decided to try installing it "whole". Only a couple pieces needed removal, such as the exhaust which protrudes out through the frame rails. Modifying some points of interference took me about three days, but it's now bolted in place. Adding fuel and oil tanks, plumbing, wiring, linkages, etc. will take at least a few more days.
The Following 2 Users Say Thank You to Jack Gifford For This Useful Post:
  #51
Old 05-03-2025, 06:48 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Thanks for the update.
Pictures would be great.
Go fast, see Elvis!
  #52
Old 05-06-2025, 12:56 AM
.., Pictures would be great...
That's what I muttered while trying to remember how I had fit everything in such a small space!
The Following 4 Users Say Thank You to Jack Gifford For This Useful Post:
  #53
Old 05-15-2025, 12:22 AM
Finished cramming everything in. The one open space is required to allow changing gears in the top-load quick-change box. Added fluids, fixed leaks, and primed all systems. Ready for some more tuning and checking.
The body panel over the engine has always been a two-man job, so I'm working on hinging it to the passenger[?]-side, to be able to deal with it by myself.
ID:	651652   Click image for larger version
The Following 6 Users Say Thank You to Jack Gifford For This Useful Post:
  #54
Old 05-16-2025, 09:14 AM
Mr Anonymous's Avatar
lookin' good!
Clutch Guys Matter
53 Studebaker, 400 pontiac
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
  #55
Old 05-18-2025, 11:38 PM
Just finished what I promised myself after destroying the engine by not fully opening the fuel shutoff prior to a run. Added a very bright lamp on the dashboard which is illuminated whenever the shutoff valve is not fully open.
  #56
Old 05-19-2025, 08:20 AM
sdbob sdbob is offline
Thank you for sharing. Just amazing all the engineering.Good luck.Sometimes I wonder about luck is it real or is success measured by preparedness?
  #57
Old 05-19-2025, 08:39 AM
PAUL K's Avatar
That's learning the hard way ..... Been there, done that!
Two cylinders are better than no cylinders!
Go fast, see Elvis!
  #58
Old 05-24-2025, 12:44 AM
Removing the body panel over the engine has always been a two-man job. So I just finished hinging it on one side, so I can deal with it by myself.
  #59
Old 05-25-2025, 08:08 AM
It worked for Mickey Thompson, It can work for Jack Gifford! Keep up the good work.
  #60
Old 05-28-2025, 01:25 AM
I had to ditch the Hilborn scoop, since the hinged body panel would not clear it. So I built a mini-scoop for the Hilborn 2-port (block-off plate over the back two ports of a 4-port injector).
