Old 03-02-2025, 01:01 AM
70 Blackbird 70 Blackbird is offline
Default Suggestions for cleaning gauge face?
Looking for suggestions for cleaning the metal face of some gauges. The face doesn't have any rust, just some grime that needs to be cleaned up. I don't want to harm the paint, color and detail is still good.
Thoughts?
70 Blackbird
Old 03-02-2025, 10:23 AM
78w72 78w72 is offline
The actual face of the gauge with letters & needle? If so be very careful, the white letters can smear if too much force or the wrong product is used and the face is deteriorated at all from age/sun. I would start with a light mix of dish detergent and micro fiber cloth, test an unseen area then go from there if no signs of damage.
Old 03-02-2025, 11:09 AM
Yes, I am wanting to clean the face with the lettering. There isn't any surface rust or bubbling in the paint.. but does have some grime from it's years of service..
Old 03-02-2025, 08:55 PM
Ramairnacho Ramairnacho is offline
Default guages
send guages to get restored
Old 03-02-2025, 11:35 PM
I am a bit more of a low budget guy.. Gauges all work, just need to clean up the faces.. Hoping that someone has crossed this bridge before and is willing to share. If not I will give it a go and share my results..
Old 03-03-2025, 02:45 PM
unruhjonny's Avatar
From my experience, any more pressure on the gauge face than you might get from a light brushing with a used makeup brush, is likely to smear the printing on the gauge face.
I also learned the hard way that a tach needle can break off surprisingly easy.
I would guess that some sort of steam cleaning might work, but the main problem is that the ink used on the gauge face tends to act like pastel (think: soft chalk) - so I cannot stress enough to be careful.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 03-03-2025, 09:54 PM
70TA-RAIII 70TA-RAIII is offline
Maybe a Q-tip to get the specific dirty areas, but I wouldn't touch any of the white or red on an old gauge.
70 TA RAIII M20 05D
70 TA RAIII M20 06B
The Following 2 Users Say Thank You to 70TA-RAIII For This Useful Post:
Old 04-19-2025, 08:26 PM
Took a while to attempt this.. I was somewhat successful using dish soap warm water (140 degrees) and a makeup brush. Thus far without damage.. These are all somewhat recent purchases, the clock had obviously been stored in the open, real dusty. While it did clean up pretty well, there are some slight surface imperfections which I don't think additional cleaning will help with.
The tach appears as if a prior owner attempting some cleaning, leaving some marks and grime. I have gone over it several times, wash, rinse (warm water as well) and dry with a can of air. I need to work on it some more but it is looking a lot better.
I am not seeing a downside to the attempt..
ID:	650522   Click image for larger version
ID:	650523   Click image for larger version
ID:	650524   Click image for larger version
Old 04-19-2025, 09:28 PM
Looks MUCH better!
John
70 TA RAIII M20 05D
70 TA RAIII M20 06B
