I just reinstalled my rear 1/4 glass after having them removed for over 10 years. It wasn't difficult, but my interior was out. If your weatherstripping (and interior panel) is in place and if the plastic vent in the door opening is installed, you can't see much of anything. Remove the vent in the door opening first and see if that improves your view. If not, you will have to remove the interior panel with its window seal to see more.
If you have to remove the window, there is an access cover inside held in by 6 screws. The actual window register is held in by four bolts.
Kent R.
