Nice car and it sold for some good money. I like the color too.
https://bringatrailer.com/listing/19...tiac-catalina/
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. |
WOW
The difference between inlaws and outlaws? Outlaws are wanted |
Might be a boat but it’s got the right engine and it’s a Clean looking car.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Did north pick this one up?
Looks like it would fit right into his collection.
1974 Firebird Esprit 1953 Buick Special Riviera 1963 Riviera 1963 Thunderbird 1965 Mustang 1965 Skylark Sport Coupe 1965 Dart 170 Wagon 1965 Corvair Monza Convertible |
The ’69 Catalina from BaT came home to my brother Dan three weeks ago today. I got to see it for the first time today, and I have to say it is a sweet car in amazing original condition…except for the newer paint, but that is even nice for a driver. Dan’s been busy checking everything over, going through the brakes (repainted the red MC to black), all the fluids, changing the oil & filter, new R45S plugs to replace the too cold R43S’s, corrected the timing and advance, and went through the Q-jet to clean and confirm jetting (factory still). He’s working on light bulb replacement throughout and getting it ready for its first spring outing in May. It whistled 9.5 compression cold, so probably close to 10.0 warm.
Dennis |
| The Following 4 Users Say Thank You to SD455DJ For This Useful Post: | ||
That’s great Dan got this car. My grandpa ordered a 69 Ventura exactly like this. Same colors,428,gauges,3.23,s. I tried to talk my uncle into buying. Awesome car!
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
| The Following User Says Thank You to J GLASGO For This Useful Post: | ||
Thanks John! Dan is considering pulling the engine to replace the oil pump and driveshaft with a 60 lb. pump and HD shaft...and pull a cap, or two, to see how the bearings are holding up.
Dennis |
Nice to see it found a good home. Best of luck with it.
Mark
| The Following User Says Thank You to Mark Simiele For This Useful Post: | ||
Funny how I know both the seller and buyer. :-)
I only know the buyer...lol. Dan weighed the big Cat and it topped the scales at a paltry 4201 lbs with a half tank of gas. With a full tank its 4300 lbs. With Dan's butt in the seat and a full tank of gas it's 4350 lbs race weight. That's only 300 lbs heavier than our '70/'71 GTO's!
Dennis Last edited by SD455DJ; 03-12-2025 at 06:30 PM. |
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
Whoops! Good catch...lol! 4450 lbs. I meant to say.
Dennis |
| The Following User Says Thank You to SD455DJ For This Useful Post: | ||
