Old 03-12-2025, 08:12 AM
Skippy597's Avatar
Skippy597 Skippy597 is offline
Default 6.8 rod choice I vs H
Ordering up the pistons and rods here shortly for my 400 stroker build. 4.25 scat forged crank, should be 500-550hp. By all accounts the pn# 2-ICR6800-7/16 I beams should be completely fine at my level and $200 cheaper, is there any reason to upgrade to the pn# 2-454-6800-2200 H beams? Also I don't think my power level warrants the arp2000 upgrade and plan on using the 8740 hardware choices to save $$$. But I'm looking for opinions from the great mind pool here, please and thank you.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
Old 03-12-2025, 08:13 AM
Skippy597's Avatar
The rod choices
ID:	648813   Click image for larger version
Old 03-12-2025, 08:49 AM
grivera's Avatar
grivera grivera is offline
Butler has the H- Beams for $543
https://butlerperformance.com/c-1459...d-journal.html
Will Rivera
Old 03-12-2025, 09:32 AM
steve25 steve25 is online now
You don’t need the added strength of a H beam, but besides that the H beam design keeps a lot more oil kicked up around the crank.
Old 03-12-2025, 11:09 AM
Skippy597's Avatar
Originally Posted by grivera View Post
So this is where my OCD kicks in and freaks out about the thought of running a scat crank with eagle rods lol. I know there would be no issues what so ever, but for some reason it just bugs me.
Old 03-12-2025, 11:22 AM
tom s tom s is offline
I went with ARP2000 and H beams.Tom
Old 03-12-2025, 11:32 AM
grivera's Avatar
I get it re: OCD.
I assumed dollar amount was the main concern based on opening thread, once checked out by the machine shop, it’s all the same and likely from the same Chicom foundry.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 03-12-2025, 01:01 PM
Skippy597's Avatar
Well it is budget driven but the budget is blown anyways so... Lol. More so just wondering at my power level if there is a reason to upgrade. I have heard the same about H beams causing more windage as well, which makes sense due to their design. I'm fine spending money where it's warranted, like upgrading to arp2000 hardware on the I beams is only $70 more.
Old 03-13-2025, 04:55 PM
soupman soupman is offline
I had the same decision also. I went with H beams and arp, same as tom s.
Old 03-13-2025, 05:18 PM
Have a set of stock Pontiac length Crower I beams in one 455HO bottom end.
Few months ago began watching for a set of 6.7 or 6.8" BBC I beam rods for next build.
Would like to get some feedback on total gram weight of various aftermarket BBC rods in 6.7 or 6.8 length. Am sure many have gone this route, anyone like to share?
Old 03-13-2025, 05:32 PM
My latest build is a pontiac length and pin.Tom
Old 03-13-2025, 06:55 PM
Skippy597's Avatar
Seems like I'm going with the scat I beams.
Old 03-13-2025, 10:40 PM
In reality, either rod will work in your application. “I” beam rods are actually stronger than “H” beam rods but are also substantially heavier as well. Be advised that nearly ALL offshore forged rods( Eagle are offshore forged rods) need a bit of touching up on the big end and on the pin end. Molnar and SCAT seem to be the exception. Consider this: both Oliver and Carrillo rods are considered to be the ultimate in strength in domestic forged rods; both are “I” beam construction.
Dr. Thomas Sowell
Old 03-13-2025, 10:56 PM
My Carrillo rods are H beams?Tom
Old 03-14-2025, 12:45 AM
Skippy597's Avatar
I don't know about either being substantially heavier than the other. I think the H beams are advertised as 810 grams and the I beams as 820 grams.
Old 03-14-2025, 02:58 AM
Dragncar Dragncar is offline
Just get Molnar H beams and be done with it. They are the best rod for the money period.
Old 03-14-2025, 03:42 AM
65 Lamnas's Avatar
I went with the Molnar H-beams due to their quality and the weight savings over Eagle and Scat
The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post:
Old 03-14-2025, 10:35 AM
Skippy597's Avatar
So looking at the molnar H beams they come in around 749 grams which is significantly lighter. That sounds like enough to sway me and make everything happier at rpm.
The Following User Says Thank You to Skippy597 For This Useful Post:
Old 03-14-2025, 11:42 AM
charlie66's Avatar
Talking
I vote H-beams. Better to have them in case you want to add power later on down the road. Over kill is the way imo...
My Half AN Injun.....
Old 03-14-2025, 02:50 PM
Tom, Carrillo produces both. The Carrillo rods I’m most familiar with ( SBC sprint car rods) are “I” beams. Fantastic rods IF you have the budget for them. I’m going with Pontiac length/BBC rod journal Molnars. Did you ever get your 301 based RAV built?
Dr. Thomas Sowell
