I think I’m going for a painted look on my thermostat housing.
Are the after market aluminum ones all the same or are there sources for better made and finished ones? Those cheap chrome ones at least for chevys start flaking and the less expensive rotating billet one I’m Leary of also. I’m not going the 130$+ route on a billet one. Thanks for the help! |
Rock auto has cast iron ones for around $12 . Better finish - IDK but I painted it and it looks as good as the factory aluminum that was roached out .
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Thanks for the tip’s fellows.
My bad for not telling the year and model. My car is a ‘75 TA. |
I just flipped open my latest Ames catalog, and your housing is... wait for it; . .. ... $17.
Thanks for all the help!
This is a great forum |
| The Following User Says Thank You to 1911a1 For This Useful Post: | ||
Just get a used original take-off. Either way, you'll readily find out that gaskets usually leak and will end up just using straight RTV as the service manual recommends.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop ![]() |
I just bought one from Oreilys online store like a month ago. Cast aluminum. Fit fine, doesn't leak. Could easily be painted. I think the cast grain is a little more course than the factory unit, so maybe it doesn't look perfectly stock but only the most anal of observers would notice.
I cant remember the brand, but it was about $20. There were two options IIRC. A dorman unit and the one I bought. My original unit had internal corrosion that made the hole too large to hold down the thermostat adequately. Because of that experience I would personally advice against a 60 year old take off. This short video doesn't show the new one because I didn't have it yet, but it shows the problem I discovered I had and was leading to strange cooling issues. https://www.youtube.com/shorts/FHUtY2uQkkY
| The Following User Says Thank You to RocktimusPryme For This Useful Post: | ||
i really like the CVR one i have, but OUT was it expensive, but i do like the orings and the ability to swivel it....
but over a $100+ now, i'd explore other options for sure |
"...ridge reamer and ring compressor? Do they have tools like that?" |
Car used to run bang on the thermostats +/- 2 degrees unless you sat at idle for a good long time. Then it would creep. Then all of a sudden it was taking longer than normal to get to temp but once it got there it wasn’t staying put. Especially in hot weather. (In the winter it wouldn’t get to temp at all) It’s because the stat was sitting cockeyed and not sealing. Caused all sorts of issues because it wasn’t controlling coolant flow like it should have. Once I replaced the housing I’m back to where I was. It will still creep up higher than I like if I sit in a long drive through. But normal driving it’s bang on the thermostat.
The bare aluminum neck that Ames sells has worked well for me. You can paint it easily.
https://www.amesperf.com/parts/23926/
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright" |
I just bought the MotoRad brand thermostat housing from Rock Auto where it’s listed as “steel”. The one in the box is cast aluminum. At the time of the order, it was the only one in stock.
https://www.rockauto.com/en/catalog/...r+outlet,10337
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 05-16-2025 at 01:13 PM. |
| The Following User Says Thank You to grivera For This Useful Post: | ||
| The Following User Says Thank You to 64speed For This Useful Post: | ||
https://butlerperformance.com/i-2445...pp-tp-042.html
Tim Corcoran |
