Old 04-04-2025, 10:29 AM
joes455 joes455 is offline
Default Oil filter with bypass
Looking and can't find any oil filters with built in bypass,found 1 fram-hp5 but not sure if quality is any good due to the rumors of Fram filters,also curios if wix 51258 has one or not.Thanks in advance
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 04-04-2025, 10:49 AM
Formulas's Avatar
Formulas Formulas is offline
I .. THINK .. the Fram HP line is better built than regulars..
With the amount of offshoring today I don't trust anything but I have to buy something so I buy the higher price point of any given filter in hope of getting a product that meets minimal standards
Old 04-04-2025, 11:35 AM
mgarblik mgarblik is offline
No bypass valve on the 1258 WIX filter according to the specs. on fleet filter.com. It does have an anti-drainback valve.
Old 04-04-2025, 12:12 PM
Steve C. Steve C. is offline
"With the amount of offshoring today I don't trust anything"
Valid issue today.
Fwiw, many years ago when racing we used a HP2 racing filter. As research found, at least back then, their racing filter was a different construction than the regular off the shelf Fram filter.
Old information here:
Old 04-04-2025, 02:37 PM
Formulabruce's Avatar
Pontiacs have a bypass in the oil filter engine adapter.. Napa are WIX filters IIRC.
" Long may we DRIVE !"
Old 04-04-2025, 07:42 PM
sdbob sdbob is offline
I used HP2 s forever in my SDs then couldnt find them, never a problem. A friend used HP2s in his dirt track RAV. I guess now there different. I'm thinking going to Baldwin this year.
Old 04-04-2025, 07:49 PM
Fram HP Series Oil Filters HP2
For maximum performance and durability on the street or at the track, trust Fram HP Series oil filters. They offer twice the oil flow rate and four times the dirt-holding capacity of standard oil filters. Their extra-thick steel cans and heavier gauge tapping plates are designed to withstand the high pressures and flexing caused by demanding driving conditions. Tough steel end caps hold a spiral-shaped center tube to offer more durability and protection against collapse. Fram HP Series oil filters are compatible with all oil types and have been optimized for racing and high performance street cars.
https://www.summitracing.com/parts/f...Acm9Z06wZL1kD_
Old 04-04-2025, 09:23 PM
Default From the RockAuto website
High Performance; Spin-on
FRAM Racing® Filters are optimized for both racing and high-performance street cars, and are compatible with all oil types. Feel confident knowing a heavy-gauge tapping plate and an extra-thick steel can will withstand the high pressure flexing caused by demanding driving conditions. A spiral-shaped center tube provides protection against collapse, and tough steel end caps add even more durability. A screen-over 22psi filter bypass valve provides additional protection against larger contaminants.
Features & Benefits:
Low-restriction racing media designed for high oil flow. The media features 94% efficiency @20 microns for excellent engine protection.
Silicone anti-drain back valve.
Recommended maximum oil flow: 10-18gpm, depending on model.
Maximum burst pressure: 350-500psi, depending on model.
Maximum operating pressure: 200psi on all models.
Old 04-04-2025, 09:34 PM
I just now noticed the Summit site stated "not available".
My apologies for any confusion caused.
Old 04-05-2025, 03:47 AM
Kenth's Avatar
Kenth Kenth is offline
Why plug Pontiac's original bypass in the filter adapter and then use a filter with bypass???
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 04-05-2025, 06:44 AM
steve25 steve25 is online now
Agree 100% with the above!
Only if you plug the oil bypass in the oil filter adapter do you then need a filter with a bypass.
If you run a remote filter plumbed off the block without the oil filter adapter then you need a filter with a bypass.
But this brings up a few very important questions in my mind that I have not seen discussed here.
1)
Are you thinking the factory did not know what they where doing when the put a bypass in the oil filter adapter ?
2)
Do you think that the factory did not research the bypass volume / flow rate needed to keep the motor alive during bypass conditions, so you think you know more then the factory engineers in regards to this system?
3)
What makes you think that a filter with a bypass designed for another totally different motor can match the needed flow rate that Pontiac had in the stock adapter bypass?
When I looked into the details of the remote set up I used I went with two 2 Qt filters.
While the ones I used did have a bypass the flow rate of the two big filters ment that the bypasses never opened even with cold oil as long as it was not straight 50w and the air temperature was above 40 degrees .
Old 04-05-2025, 09:07 AM
Yes I'm running relocated oil filter and cooler.Lines are attached directly to tapped block.So I need a bypass style filter.Mainly for cold start ups and less wear on the composite distributor gear.
Old 04-05-2025, 09:15 AM
Moroso filters come in a number of configs.
Old 04-05-2025, 09:23 AM
Some choose to block the bypass on the OE adapter, and don't run a bypass filter. That's the point, is to ensure everything goes through the filter.
It has drawbacks, no bypass, as well as remote filter setups.
As long as you are aware of the potential issues, and keep an eye on it, then there usually isn't a need for a bypass.
Old 04-05-2025, 09:49 AM
67Lemons 67Lemons is offline
Napa filters are no longer made by Wix, they changed to Premium Guard which is a decent filter but definitely not a Wix, the change happened about 2 years ago.
1972 GTO
K&n is showing to have a bypass,is this correct?
Old 04-05-2025, 10:25 AM
Where it’s mounted do you have the room for a 1 Qt size filter?
The typical Chrysler / Ford 1Qt filters have a bypass in them but they still require a in engine bypass because they still can not handle high rpm flow volume.
Old 04-05-2025, 10:48 AM
OK k&n does not have bypass,but I just called oriellys for a fram hp5 and they crosses it over to a wix 51244 which has bypass and is 5 1/2" tall
Old 04-05-2025, 10:50 AM
With a remote oil filter and/or an accumulator, often the factory bolt-on oil filter adapter is eliminated. That is one of the only reasons I can think of.
Old 04-05-2025, 10:58 AM
I am not sure that is entirely true. Unless something has changed recently, Premium Guard is the 3rd choice product provider for NAPA in their Gold and Platinum series filters. For the Gold filters, Mann/Hummel/WIX is first choice, Champion Brands, is second, and Premium Guard is third. The NAPA "Performer" filters are made by Champion Brands and a few by Premium Guard as well. The thing I DON'T like is you can't tell from the box, what is inside. Same part numbers, many different countries, it's confusing, on purpose. I have NAPA Gold Filters on the shelf from, USA, Vietnam, Germany, China, Brazil, Mexico. I will say, I have not had a problem or issue with any of them.
