Old 06-22-2025, 07:49 AM
tjdjr's Avatar
tjdjr tjdjr is offline
Default Cam Lobe Width !
I am working on rebuilding a 400 and ordered a Melling 068 from butler. It wasn't in stock so for an upcharge sent their version they offer with Comp Cams. While it was being shipped i found a Melling cam local spc-7. I did have a used 068 from years ago and lined them up for the heck of it. I can't believe the difference in Lobe Width on the new cams vs the older one. The new 068 and butler 068 are a lot narrower than the old 068 from melling. Any thoughts?
ID:	653247   Click image for larger version
The Following 2 Users Say Thank You to tjdjr For This Useful Post:
Old 06-22-2025, 08:26 AM
steve25 steve25 is online now
You’re not the only one questioning this because this is something a noticed decades in an auto parts store I use to work in which was also a speed shop.
If I recall right I think it was with a Cam Dynamics cam that I noticed this .
Really makes me want to find out what the minimum lobe width is to have the lifter spin properly.
Old 06-22-2025, 08:43 AM
tjdjr's Avatar
I am half tempted to return the new cams and use the older one.
Old 06-22-2025, 09:57 AM
mgarblik mgarblik is offline
If your concerned about lobe width, you could send your old, OE 068 to Bulllet/Ultradyne and they can regrind/dress/polish it for you. Less expensive than a new cam and you get a nice new surface to break in a new set of lifters. That's an option. I too have noticed the lobes being more narrow the last 20-25 years on many cams. Can't say if that's a problem or not, but millions of cams have been made that way.
Old 06-22-2025, 10:06 AM
scott70's Avatar
scott70 scott70 is offline
When they regrind a cam I’m assuming the original parameters / specs cannot be kept?
Old 06-22-2025, 10:17 AM
P@blo's Avatar
P@blo P@blo is offline
You can also see the lifter path does not use the entire lobe width so the additional lobe material is moot. Cam break in issues has a lot of moving parts.
Okay I spoke with the tech from Johnston lifters and he was nice to share some information with me/us.
They used to use a foundry in Chicago up to about 10 years ago. Then quality could not be maintained so they went out of the FT making business as nothing they could find in the USA was up to snuff quality wise. He indicated that the two main problems are:
1) During casting, on a casting tree, the face must cool first before the lifter. Adds costs and steps to the process.
2) Asicular carbides must be present at least 200 thou deep.
3) Lifter makers are only concerned with hardness which is a major problem when both the first two points above are not achieved.
With even HLJ lifters failing we may have lost the technology for good now actually. Anyone want to call HLJ and ask how they cool their lifter face and is their acicular cabides at least 200 thou deep?
Starting to wonder if made in the USA does not mean much anymore...
Last edited by P@blo; 06-22-2025 at 10:37 AM. Reason: Added lifter information from HLJ oldtimer tech
Old 06-22-2025, 11:14 AM
Stan Weiss's Avatar
Unless your cam is badly warn they should be able to regrind it to original specs. The only thing is you will now have a smaller base circle diameter, and will need to check if your push rod length is OK or you need new push rods.
Stan
Pontiac Pump Gas List
Old 06-22-2025, 12:32 PM
dataway's Avatar
dataway dataway is offline
Wonder why the older cams have the wider lobes if it was unneeded, I'd imagine they had the technology back then to understand it was unused.
Might be more in play than we realize. Larger lobes might play some part in the manufacturing process, perhaps easier to get an accurate lobe taper etc.
In operation ... maybe a larger lobe drags more oil to the center of the lobe.
Back in the day, just like today, they were pretty good at shaving off pennies, makes me think there may have been a reason for wider lobes.
Or I guess it might be as simple as back then a wider lobed casting could be used for more different applications.
Old 06-22-2025, 01:29 PM
tjdjr's Avatar
I bought the Butlers' Johnson lifters and when ordering the cam basically said its a 50/50 shot making it past break in and another crap shoot getting the 500 mile mark. I just opened up the 400 I took out, been running this engine 20 years, bottom end getting real tired, but the cam in it is a Crane 878 with whatever lifters and it looks great. Fingers crossed when I get to the break in process. Thanks for the replies.
Old 06-22-2025, 01:31 PM
Formulas's Avatar
Formulas Formulas is offline
Cams back in early 80s late 70s were showing up with both size lobes..
I noticed the difference back then but nobody seemed to care or talk about it..
My old HO .. HC-03 cam is a fatty and my Comp AH294-8
Old 06-22-2025, 02:03 PM
Jay S's Avatar
Jay S Jay S is offline
For stock cams like a 066 or 068 I do not think the lobe width will make any difference in longevity. On stock type cams I think the narrower lobe is easier to break in, and the lifter machining doesn’t have to be quite as perfect. Some of the original factory Pontiac stock cams were ground on the narrower lobes, they were not all wide lobes. On bigger cams where the profile is using more of the lifter face the lobe width is a lot more important. A big profile on a narrow lobe there ends up with less footprint where the lifter has the highest acceleration. That is why most mechanical cams use the wider lobes and the EPC cores are EP-2 instead of the standard cores. What I have seen on the narrower lobes and bigger profiles is the lifter digs into the base circle the closing side of the base circle, and the taper gets removed quicker on the opening ramp.
Comp cams and generally uses narrower cam cores from EPC. Crower uses the narrow lobes also. The letter EP-1 or EP should be cast into on the core somewhere between the lobes on EPC cores. Melling always uses CMC cores and has a little wider lobes with the letters CWC cast into the core. Both EPC and CMC cores are cast at CWC though.
Old 06-22-2025, 03:38 PM
geeteeohguy's Avatar
Probably because cams and lifters worked 99% of the time back then. I never had a failure, and didn't know anybody who had one, personally.
Catastrophic cam and lifter failure is a 21st century phenomenon.
Jeff
Old 06-22-2025, 05:49 PM
Jay S's Avatar
If you have a good used Crane 96878 068 copy with lifters matched up to the cam I would pick that over any thing new.
Old 06-22-2025, 06:20 PM
Jay S's Avatar
Bulter’s new warm and fuzzy HFT disclaimer!
Old 06-22-2025, 08:59 PM
Torquewar's Avatar
Torquewar Torquewar is offline
Interesting that Butler has that disclaimer. Well it’s been discussed on this forum dozens of times times , take your chances . When I went to the stroker route had a chat with Dave Bishopp from SD Performance back in 09 . He said nothing will be built in his shop other than a roller set-up. I ordered the Old Faithfull then. My go to guy has the same sentiment. It’s the world we live in now.
Old 06-22-2025, 09:44 PM
BILL BOWMAN1's Avatar
I wanna go back to the 80s. Lube it up, stick it in, and drive it!
Old 06-22-2025, 09:55 PM
Torquewar's Avatar
Yes Bill …was never an issue then .
Old 06-22-2025, 10:13 PM
242177P's Avatar
242177P 242177P is offline
Not entirely true. Chebbies in the '80s ate a bunch of
cams. Neighbor dropped a lifter into the oil pan, LOL.
But I never had trouble with Pontiac cams (including
a used one) in the before times.
Old 06-23-2025, 09:20 AM
tjdjr's Avatar
Fingers crossed ! Getting closer to putting it together. So between the new comp/butler 068 and Melling 068, which do you feel is the better way to go? Thanks
Old 06-23-2025, 01:08 PM
Jay S's Avatar
The melling might be safer. I would want to know more about the Bulter cam to decide though. It might be fine too. Personally I would return the HLJ lifters and try the DLC face coated Comp High energies.
I don’t know what profiles Bulter use’s, whether it is a close copy or their own version. Can also look at the Bulter version for letters like EP or CWC. There are some cams from Comp that have narrow lobes and have a CWC logo that I think are very poor quality cores.
