Old 03-19-2024, 08:10 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Horn
WTB driver side horn.
  #442
Old 03-20-2024, 04:30 AM
Drag Star Le Mans's Avatar
I have a few and will function test. Do you need a year specific or just functioning?
DragStarLeMans
  #443
Old 03-20-2024, 07:37 AM
PLongen PLongen is offline
Default 63 Power Steering Pump Pulley Wanted
Looking for a 63 LeMans power steering pump pulley.
Specs for the pulley would be good too.
Than you,
Pat
  #444
Old 03-20-2024, 05:36 PM
hobbygto65's Avatar
I'm kind of wondering now, the horn was for my 63 Lemans but now after looking at my wiring diagram it only shows one horn on the passenger side.
  #445
Old 03-26-2024, 03:50 PM
deanremix's Avatar
deanremix deanremix is offline
Still looking g for fenders and quarters for a 61 tempest if anyone has a bead on some lmk
  #446
Old 04-13-2024, 08:16 AM
Found pulley
thanks
  #447
Old 04-24-2024, 09:25 PM
Apsesia Apsesia is offline
Default Rear end
Looking for a or higher gear ratio rear end for a 1963 lemans. Have a 2.91 in the car now. Have found a 3.30 but was wondering if anyone has any higher. Car is a 326 auto I am in Mooresville nc so if close even better.
  #448
Old 04-24-2024, 09:45 PM
tom s tom s is offline
They did make a 3.90 gear,had a set in my 63HO car I bought new in 63.I think pretty rare and takes a diff carrier as I remember.Dont know what uother gears were inbetween that required a dif carrier.Tom
  #449
Old 04-25-2024, 05:52 AM
I believe they also had something around a 3.55 and 3.78. Those 3 seem to all be harder to find. I’ve seen a bunch if 3.09.
  #450
Old 04-25-2024, 09:01 PM
firefour1 firefour1 is offline
Default PS Bracket
Originally Posted by PLongen View Post
thanks for the pictures that helps. All need now is a templet to make the front bracket. It shouldn't be to hard.
Pat
Have attached the photo of the entire assembly. The two black ones are needed, the other two are part of the alternator mounting. Flat plate in the front, angled part connects to the motor mount bracket. The PS pump is fixed in place, the belt is tensioned off of the alternator adjustment. Let me know if there is anything else needed.
  #451
Old 08-02-2025, 11:26 PM
Flexplate for 63 V8. My friend is in need of one and lives in Canada. The land of no 63 LeMans parts.
DragStarLeMans
  #452
Old 08-05-2025, 12:27 AM
ricks63 ricks63 is offline
Default 63 paarts
Hi i have lots of 63 Lemans Tempest parts, located in Thunder Bay Ontario. Contact me. Thanks
  #453
Old 08-06-2025, 02:35 AM
Stop looking, I dug deep into my stash and found one.
DragStarLeMans
  #454
Old 03-04-2026, 12:28 AM
rdtripn_rte66 rdtripn_rte66 is offline
I can look this week - I may have one in shed. Robin
Robin Triplett
Midwest Director of the Little Indians Club
417-456-9858 cell
63 Lemans convt. Present
1970 350 Firebird motor built to 69 350 HO specs
Aces EFI and Tanks Inc 64 GTO EFI tank (24 gals)
700r4 with 3:23 rear w PB - 69 Camaro rear disc brakes and early S10 front disc brake setup
65 GTO rally guages 67 console ratchet shifter 70 bucket seats 62 GP rear seat w arm rest and center speaker grill (cut down 8")
  #455
Old 03-04-2026, 12:38 AM
I seen that BLUE pc the other day in a parts bin - if still needed let me know
[email protected]
Robin Triplett
417-456-9858 cell
  #456
Old 03-04-2026, 12:41 AM
maybe a Pair was an option like the PS sun visor. I just dis-assembled a 15 option 63 Lemans and there were two horns
Robin Triplett
417-456-9858 cell
  #457
Old 03-04-2026, 12:43 AM
Originally Posted by deanremix View Post
I'm in need of front fenders for either a 61 or 62 tempest.
There is a 61 for sale in FL for only 800....
Robin Triplett
417-456-9858 cell
  #458
Old 03-04-2026, 12:46 AM
Looking to put power steering on my 63 Lemans. I need the 4 cylinder power steering pump brackets and other related parts.
Thank you,
Pat
I have a 4 cyl PS pump I have sold and delivering to Norwalk in July - I will get some pics and post them to here for you. Has the brackets on it.
Robin Triplett
417-456-9858 cell
  #459
Old 03-04-2026, 01:14 AM
I am looking for a park cable for a 63 LeMans.
Thank you
did you find a parking brake cable? I have it from the pedal assm back to the rear axle but nothing to the rear wheels.
Robin
Robin Triplett
417-456-9858 cell
  #460
Old 06-04-2026, 01:11 PM
hobbygto65's Avatar
WTB complete signal light switch for 63 Lemans.
