Old 08-11-2025, 11:09 AM
Originally Posted by 73_Lemans_350 View Post
Yesterday my wife and I took the LeMans to a free local car show. I parked next to a Bonneville, and found a nice 77 Can Am! Weather was perfect.
About 25 years ago.. I had a brown '73 Lemans with Centerlines. At glance I thought it was the same car.
  #1442
Old 08-12-2025, 12:10 AM
VCho455's Avatar
VCho455 VCho455 is offline
Started fitting new parts on the Firebird.
ID:	655564   Click image for larger version
ID:	655565   Click image for larger version
ID:	655566   Click image for larger version
ID:	655567   Click image for larger version
The Following 3 Users Say Thank You to VCho455 For This Useful Post:
  #1443
Old 08-14-2025, 09:30 AM
Longs's Avatar
Longs Longs is offline
Replaced positive and negative battery cables on my '67.
The Following User Says Thank You to Longs For This Useful Post:
  #1444
Old 08-14-2025, 02:46 PM
Keith Seymore's Avatar
Keith Seymore Keith Seymore is online now
Heading over to the pre Dream Cruise in a little bit in the GP.
K
'63 LeMans Convertible
'63 Grand Prix
The Following 3 Users Say Thank You to Keith Seymore For This Useful Post:
  #1445
Old 08-14-2025, 10:56 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Got the radiator all flushed out, got the rebuilt rear end put back in, and took it for a little 9 mile easy drive for the break-in.
Tomorrow, another little drive, then recheck everything and let her rip!
The Following 2 Users Say Thank You to gtokid1968 For This Useful Post:
  #1446
Old 08-15-2025, 08:10 AM
PAUL K's Avatar
PAUL K PAUL K is online now
K
Pictures are always nice
Go fast, see Elvis!
  #1447
Old 08-15-2025, 05:19 PM
carcrazy carcrazy is offline
Replaced the existing positive battery cable with a new 2 gauge cable. Also replaced the current starter with a RobbMc with the pinon support.
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
  #1448
Old 08-15-2025, 05:52 PM
Verdoro 68's Avatar
Took the seats out of the Ventura and dropped them off at the upholsterer. Can't wait to get those back to their groovy plaid '70s glory.
The kids and I went over to Martinez for the monthly downtown car show and to grab some dinner. Got a laugh out of my daughter's hair blowing in the wind on the way. Saw a pretty sweet '67 GP convert there. Great cruising weather on the way back so we took the long way and stopped for ice cream.
ID:	655759   Click image for larger version
ID:	655760   Click image for larger version
ID:	655761   Click image for larger version
ID:	655762   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 10 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1449
Old 08-15-2025, 08:12 PM
Drove this earlier today.
The Following 8 Users Say Thank You to 71GP76TA For This Useful Post:
  #1450
Old 08-15-2025, 11:12 PM
post toastie's Avatar
Drove my 70 to work today including a few miles on the freeway . tall tires help with 3:90 gears.
The Following 2 Users Say Thank You to post toastie For This Useful Post:
  #1451
Old 08-16-2025, 01:10 AM
Redpiston Redpiston is offline
POR15'd the area under my back seat Have a couple of rust through spots, but it will at least slow it down until I have it cut out in winter of 2026.
Tried out my new ultrasonic cleaner. Cleaned up 3 pairs of front turn signals. Can't decide if I should paint or just spray some clear on them. Afraid they will rust up again with just clear.
ID:	655778   Click image for larger version
The Following User Says Thank You to Redpiston For This Useful Post:
  #1452
Old 08-16-2025, 01:51 PM
67drake's Avatar
67drake 67drake is offline
My son who I sold my ‘71 GTO to, wanted to go out for breakfast. It wasn’t raining at the time , so we took the ‘71.
‘55 Catalina
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #1453
Old 08-16-2025, 02:27 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Installed Powermaster XS CS130 with adjustable volt reg. 378028
14v solid at idle and not much of a PIA aside from the ground wire I have is C small terminal vs big ring like the PM wants so I used the small 1/4" casing bolt like my old alt.
My alt power wire is maybe 8awg but probably 10awg so I'll update that this winter.
ID:	655794   Click image for larger version
ID:	655795   Click image for larger version
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
The Following 2 Users Say Thank You to GOAT8U2 For This Useful Post:
  #1454
Old 08-16-2025, 04:29 PM
SD455DJ SD455DJ is offline
Me too! Just installed both pos & neg cables with new custom made 2-gauge cables when I installed a new HD factory rebuilt starter & solenoid on my '70 Lemans. I wish I had told the guy to make the positive cable black as well...dang!
Dennis
  #1455
Old 08-16-2025, 05:20 PM
Getting the Birds ready for the drive to the TA Nat's.
Dennis
ID:	655818   Click image for larger version
The Following 8 Users Say Thank You to SD455DJ For This Useful Post:
  #1456
Old 08-16-2025, 05:57 PM
73_Lemans_350's Avatar
73_Lemans_350 73_Lemans_350 is offline
If you look closely, you'll see a brand new sway bar under there. Got it installed late last night and took it for a drive today. Big improvement over not having a bar!
Design Engineer | Dakota Digital
1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras
The Following 5 Users Say Thank You to 73_Lemans_350 For This Useful Post:
  #1457
Old 08-17-2025, 03:07 PM
PAUL K's Avatar
Put the road race tires on the Super Duty and took the dog for a spin.
Go fast, see Elvis!
The Following 5 Users Say Thank You to PAUL K For This Useful Post:
  #1458
Old 08-17-2025, 03:49 PM
https://www.freep.com/picture-galler...s/85683945007/
ID:	655863   Click image for larger version
ID:	655864   Click image for larger version
ID:	655865   Click image for larger version
ID:	655866   Click image for larger version
'63 Grand Prix
  #1459
Old 08-17-2025, 03:55 PM
ID:	655869   Click image for larger version
ID:	655870   Click image for larger version
ID:	655871   Click image for larger version
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
  #1460
Old 08-17-2025, 04:31 PM
From the link. I think that is a Lucy Blue 72 Lemans rag. I will pass on the wheels.
