Old 08-04-2025, 12:37 AM
Probird's Avatar
Probird Probird is offline
Default Head deck insert
Has anyone had the head deck insert done lately? It used to be done by Glenn Sedig and Calvin. I slotted a head and would like to get this insert installed to fix the head and maybe prevent it from happening again in the future. Thanks
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 08-04-2025, 02:25 PM
aaronman aaronman is offline
Check with BES racing engines. Their website shows they offer this service. https://www.besracing.com/racing-eng...elbrock-victor
The Following User Says Thank You to aaronman For This Useful Post:
Old 08-05-2025, 08:37 AM
opeliac opeliac is offline
This is correct...I just picked my engine up, and they put these inserts in.
The Following User Says Thank You to opeliac For This Useful Post:
Old 08-05-2025, 11:26 AM
Probird's Avatar
I just called over there and the guy that does it’s going to call me back later sometime after 3:00 ET. The guy I talked to said it was kind of pricey. What did they charge you to have it done? Thanks
Old 08-05-2025, 06:35 PM
The inserts were 325.00, and I had the deck welded and hoops installed when they did the inserts, so I dont know how much they were by themselves since they did other stuff...
Old 08-05-2025, 11:31 PM
Probird's Avatar
Thanks. They didn’t call back today. Hopefully tomorrow.
Old 08-06-2025, 03:20 PM
slowbird's Avatar
slowbird slowbird is offline
I would love to know what they say if they call back. I have 2 sets of heads I'd like done.
Old 08-06-2025, 05:11 PM
Probird's Avatar
Preston just called back. He said if no other work needs done it’s $750. That includes the parts, install, surface head, and blend into the chamber.
The Following User Says Thank You to Probird For This Useful Post:
Old 08-25-2025, 10:38 AM
Glenn Sedig Glenn Sedig is offline
I supply the inserts to BES. I do not install them myself anymore. Tony at BES has the prints for installation dimensions required for the correct press fit to keep the inserts tight at operating temperatures. The inserts have proven to greatly improved gasket life in all brands ot race heads. Tony is even putting them into small Block Chev. heads.
The Following 4 Users Say Thank You to Glenn Sedig For This Useful Post:
Old 08-27-2025, 10:40 AM
Probird's Avatar
Thanks for the reply Glenn. BES has my heads now. Patiently waiting for them to get done.
Old 08-28-2025, 11:16 AM
Guys hate to sound ignorant but what is the insert? I am assuming to keep head bolt threads from pulling out?
Old 08-28-2025, 11:34 AM
Money Pit's Avatar
Money Pit Money Pit is offline
It goes between the siamesed valves. Helps takes away the heat.
Old 08-28-2025, 12:08 PM
Probird's Avatar
It goes in the deck of the head between the 2 exhaust valves.
Old 08-28-2025, 02:46 PM
Thanks guys.
Add the extra "421 hole" near there also or dry decked?
Old 08-29-2025, 12:13 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
what's the insert material? Heat treated?
Old 08-29-2025, 06:40 AM
Here's previous thread on them:
Inserts
plus one for the Tiger heads
Tiger inserts?
Old 09-05-2025, 10:14 AM
twm twm is offline
Smile
does anyone have the dimensions and material to share ?
for us do it yourself machinists
Old 09-05-2025, 12:07 PM
mgarblik mgarblik is offline
I would think Beryllium/copper would be a good material for the insert. But if Glenn Sedig already has done all the design and has inserts ready to sell, I would contact him directly about buying some?
