#1481
I added the trim/molding to the opera windows on my 73 LeMans.
Seems straightforward, but there were some frustrations getting them on (see where my screwdriver ended up after I threw it across the garage) 🙃
Design Engineer | Dakota Digital 1973 Lemans - 350, Centerline Auto Drags and Cooper Cobras |
| The Following 3 Users Say Thank You to 73_Lemans_350 For This Useful Post: | ||
#1482
Yes, the previous owner around 20-25 years ago put a 454 in it. I would had must rather had the original engine in it, but I have what I have at this point. My next Trans Am will be all original.
1979 Trans Am - 454 - Turbo Hydromatic 400
#1483
Fogged my new spare engine and put it away for when needed.Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
#1484
After a year of distraction by moving and other priorities, I finished straightening my front valance this month. It will need filler but considering the starting point and my low skill, I declared it good enough to prime for now.
| The Following 5 Users Say Thank You to Shiny For This Useful Post: | ||
#1485
Nothing, but I did go to the US Nationals!
#1486
Drove it.
Took a picture. Good enough for me.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 5 Users Say Thank You to b-man For This Useful Post: | ||
#1487
Pulled the rear window out of my Firebird. I needed to know how bad it was and it wasn't great but I'm happy it wasn't much worse!
And bonus I didn't break the glass!
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
| The Following 4 Users Say Thank You to VCho455 For This Useful Post: | ||
#1488
Took the '68 out for a spin.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
#1489
went to a local Cruise Night
| The Following 5 Users Say Thank You to Tempest For This Useful Post: | ||
#1490
I had the 64 and 65 running at the same time, It has been several years since that has happened.
"Bill"! |
| The Following User Says Thank You to bill ryder For This Useful Post: | ||
#1491
Finally installed the new front spoilers. Still fine tuning them but they look pretty good
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#1492
Picked up a new, soft ray vent window assembly for my 67 GTO. Started on the headliner installation today...we'll see how far I get. Planning on being done by tomorrow....then I have to install the new carpet.
My money talks to me-it usually says goodbye! |
| The Following User Says Thank You to carcrazy For This Useful Post: | ||
#1493
Got all the bows installed in the headliner and installed their proper positions tonight. Fun begins tomorrow when we see how the pulling/stretching, clipping and gluing goes.
#1494
Spent a little time this weekend checking my timing, fuel mixture screws & clutch freeplay, took her for a nice drive Saturday then a quick one between storms yesterday
1972 GTO |
| The Following 4 Users Say Thank You to 67Lemons For This Useful Post: | ||
#1495
We were down in LA for the weekend and stopped in at the Peterson. Minimal Pontiacs on display, but always a great visit. They had a handful of Harley Earl-era concepts on display. I was surprised at how rough the finish of the Bonneville Special is. Downstairs they have a fun display of cars from the '80s and '90s which included the old Pontiac Stinger concept.
We got the tickets to tour the vault too. Some cool stuff down there - arguably better than the actual museum upstairs.
| The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
#1496
Got the headliner in my 67 all glued up today.....looking pretty decent. managed to get headliner adhesive in my hair....should have worn a hat. Tomorrow I will install the trim and install the new carpet.
#1497
I took the good car out for the 3rd drive since the rebuild of the rear end.
Everything seemed great! The 2-3 shift doesn't seem as loud as before, my guess is because the rear end is tight like it should be! Now just need to fix the emergency brake cable that has never worked since i got it in 2004! |
| The Following User Says Thank You to gtokid1968 For This Useful Post: | ||
#1498
Last Monday Night Car Cruise/Show in Lapeer MI. Took the Bandit.
#1499
Here's a few good shots of Sally Field !
| The Following User Says Thank You to Cosmic Charlie For This Useful Post: | ||
#1500
Replaced the right turn signal bulb, without pulling the cluster, wasn’t easy
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
