Old 09-23-2025, 03:53 PM
Joe Joe is offline
Default 1966 TP carb tags
Hello,
Can anyone provide the correct anodize colors of the 1966 GTO TriPower
carbs (front/center/rear) aluminum tags? A 4-speed car if that is needed.
Thank you,
Joe
Old 09-23-2025, 05:04 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Joe,
We always have to take into consideration the color loss on these aluminum triangle tags from gasoline and carb cleaner etc. over the decades.
Here’s what I show from Survivor tags.
An Original ‘66 with 3x2’s below.
Front tag - bare aluminum.
Center tag - red anodized.
Rear tag - orange anodized.
I’m sure the front was also a designated color for assembly line workers identification.
PS, FYI, 1966 used a light blue spring for the throttle return. Not a yellow spring like some people think.
ID:	657590   Click image for larger version
ID:	657591   Click image for larger version
ID:	657592   Click image for larger version
ID:	657593   Click image for larger version
Old 09-24-2025, 06:00 AM
Joe Joe is offline
Thank you
The Following User Says Thank You to Joe For This Useful Post:
Old 10-01-2025, 11:13 PM
Terry M. Hunt Terry M. Hunt is offline
60’s Stuff, the photo showing the blue return spring is very interesting. It appears different from the reproduction springs available. The reproduction has a group of coils near the center with a straight section ending in a hook on either side of the coils. The spring in your photo appears to have coils end to end with shorter straight sections that end in a hook. It even appears to be wound from larger diameter wire. It’s hard to tell though without seeing this blue spring in its relaxed state. Maybe it’s an optical illusion. Are these springs really different? Interested to learn anything additional you may know.
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 10-02-2025, 02:05 PM
60sstuff's Avatar
Factory OEM throttle return springs for 1966.
Three factory’s if not more used the light Blue springs with offset hooks.
Below photos are Original Unrestored Survivor cars.
My BF=Fremont.
KAN=Kansas.
PON=Pontisc.
ID:	658127   Click image for larger version
ID:	658128   Click image for larger version
ID:	658129   Click image for larger version
ID:	658130   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 10-02-2025, 02:10 PM
60sstuff's Avatar
Original paint return springs.
1965 = Yellow with equal hooks.
1966 = Blue with offset hooks.
ID:	658134   Click image for larger version
ID:	658135   Click image for larger version
Old 10-02-2025, 05:05 PM
Default 66 TP carb tags
Thanks for the additional info and pics. I guess the blue spring is a little different, especially the offset hooks feature which appears to be included on the reproduction that our host sells. Would have never picked up on this if I hadn’t read Joe’s post and your reply. Filing this in my TriPower file for sure.
Terry Hunt
The Following User Says Thank You to Terry M. Hunt For This Useful Post:
Old 10-02-2025, 06:52 PM
SR-71 SR-71 is offline
As always, you're a wealth of information. Thank you.
The Following User Says Thank You to SR-71 For This Useful Post:
Old 10-02-2025, 07:40 PM
Do you think the blue color of the spring is the same as the earlier, up to 1965 engine blue?
Old 10-03-2025, 01:01 PM
60sstuff's Avatar
Hi Rob,
No, different shades of blue ….. but similar.
Old 10-03-2025, 06:33 PM
carbking's Avatar
carbking carbking is offline
From survivor tags:
389 W/AT
Front - purple
Center - black ??? maybe
Rear - bronze
389 W/ST
Front - gold
Center - red
Rear - burnt orange
421 - no information
Jon
Old 10-04-2025, 11:38 AM
bill ryder's Avatar
bill ryder bill ryder is offline
Do you find the carb tag dates fairly close to the cars build date??
"Bill"!
