You could get the 350 4-bbl. on non-GTO's, like this nicely optioned Sprint.
Dennis |
| The Following User Says Thank You to SD455DJ For This Useful Post: | ||
Dennis, here is what i have on the 1974 350 units.
7044268/568, 72 jets 43 pri. rods, DB sec. rods #7047806, 1/2 airvalve spring preload, #7029529 power piston spring A, X BODY AUTO. TRANS. 350 7044269, 68, 35, DB 7047806, 1/2, 7037851, A, X BODY MAN. TRANS. 350 |
| The Following User Says Thank You to Kenth For This Useful Post: | ||
Why is there such a difference in primary jets between manual and auto? 68 vs 72 seems like a big jump. Is this typical?
7044268 49-State AT 72/45 ("I think" the pri rods are 45s, book shows unusual# and I suspect a special taper) 7044269 49-State MT 68/35 7044568 CA same as 7044268 above Secondary rods (DB) are same for all 3 carbs Last edited by 65 Lamnas; 10-03-2025 at 10:40 AM. |
Only way to know for sure is to gauge the MABs, and one can assume they're a bit different which would explain the jet/rod differences. |
| The Following User Says Thank You to 65 Lamnas For This Useful Post: | ||
Didn't stick cars get the next bigger cam than autos ?... Along with slight bump in compression. .. Different rear gearing... Not as a rule but usually. That changes things a bit..
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
| The Following User Says Thank You to Formulas For This Useful Post: | ||
Not so much after compression ratios dropped with the '71 engines. '70-earlier it was a different story.
My apologies then.. .. But I don't give anything stock 71 and up to much thought anyways they probably got the upper cam of the year in stick cars that alone can cause minor changes elsewhere
You ARE CORRECT about the above tho....Pontiac did do this with the MT engines in (at least) the mid-late 60's....no question. |
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
