Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-12-2025, 09:32 PM
zygotemrsmith zygotemrsmith is offline
Default WTB 8.5 rear axle for A body
Looking in the Southern states -
Old 10-13-2025, 09:30 AM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
What year? They changed in 1973. Thanks, Bob.
Old 10-13-2025, 10:15 PM
Looking for direct swap into 69 GTO project.
I have a nice 8.5 from 71 F body - if anybody wants that -
Shipping from/tp N. Texas area
Old 10-14-2025, 03:01 PM
So, just a stock 8.5" open rear? No specific gear ratio? No posi, correct?
Old 10-14-2025, 03:06 PM
Correct
Old 10-14-2025, 03:19 PM
AG's Avatar
AG AG is offline
I have a 1972 Olds, but I'm in NH.
Old 10-14-2025, 03:21 PM
Originally Posted by zygotemrsmith View Post
Correct
Do you have a Fastenal store convenient tp you? I've shipped rears with them in the past. Thanks, Bob.
Old 10-14-2025, 03:25 PM
Dauntless1971 Dauntless1971 is offline
I believe you will need to shorten your driveshaft about one inch.
Old 10-14-2025, 03:35 PM
I may also have a driveshaft, depending on the transmission.
Old 10-14-2025, 05:21 PM
Yes, I use the one in Bridgeport Tx
Muncie M21
Old 10-17-2025, 06:58 AM
OLBLU OLBLU is offline
Have an A body from 71-72 Buick. This is an 8.5 with non tapered axles. Bought 15 of them from a wrecking yard in OK panhandle years ago. Takes all 8.5 parts.
Located in Lewisville tx
Old 10-17-2025, 03:51 PM
Ck PM
Old 06-03-2026, 08:25 PM
sberbs's Avatar
sberbs sberbs is offline
I'm looking for and 8.5 posi a-body 1975 28-Spline
Old 06-03-2026, 10:14 PM
performerrpm's Avatar
performerrpm performerrpm is online now
i have a 65 chevelle 323 non posi dif in oklahoma. been blasted and painted. being pulled out for a 9".
Old 06-04-2026, 01:11 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
I have a driveshaft for an th400 and a 8.5 in KS
Old 06-04-2026, 06:20 PM
Have '73-77 8.5 A-body bolt-in axle core rears in the racks.. Have built up a couple dozen of the '73-77 A-body style. most did not come with good gear ratios & a posi. Not a fan of the c-clip axle version
of the '73-77 A-body rear, though may have a housing in the racks.. Original 28 spline "S spring" posi's typically show wear to the clutches, & some units have side gears w spalling (pitting).
Going back 30 years, I always replaced the clutches & properly shimmed up the side gears. Not easy to do with limited avail of correct clutch side shims.
The clutches have been reproduced for the last twenty years, but they are expensive. Just something to factor in if you stumble into what will typically be an expensive core to have gone through.
Old 06-05-2026, 02:35 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default 1970 chevelle 8.5
I have a 1970 Chevelle 8.5 open diff I can sell you. Very nice condition. I am in Dallas.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
