Old 10-17-2025, 10:26 PM
slowbird's Avatar
slowbird slowbird is offline
Default Ideas for weight reduction on 65 GTO
I'd like to take off 50-100lbs from our 65 GTO. I'm looking into light weight upper and lower a-arms. Any other ideas?
Old 10-17-2025, 11:18 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Treadmill twenty minutes, health rider twenty more
Go fast, see Elvis!
Old 10-18-2025, 01:04 AM
performerrpm's Avatar
and cut back on carbs as well��
Old 10-18-2025, 03:39 AM
65 Lamnas's Avatar
Wheels and any other items (calipers, rotors, etc.) that are unsprung weight are most beneficial and provide more bang for yer buck.
Pretty sure my aftermarket 17x8” wheels are about 22lbs each.
Old 10-18-2025, 06:46 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Aluminum block and cut down the k member
Old 10-18-2025, 06:52 AM
Pav8427 Pav8427 is online now
Aluminum rear drums.
Old 10-18-2025, 09:07 AM
Elarson's Avatar
Elarson Elarson is offline
Another vote for aluminum block plus a fiberglass hood.
Eric
Old 10-18-2025, 09:35 AM
having taken the hood off and on on my 65 it is heavy! Glass hood.
Bumpers are heavy,not as heavy as my 64 impala bumpers though! As well as pot metal front grills. I think the repop grills are plastic. Glass bumpers and with "wraps" now can be as shiny as the real thing.
I know my "regular" Global west tubular A arms aren't any lighter than the factory ones.
Wheels can make a big difference as well as tires.
Old 10-18-2025, 10:14 AM
PAUL K's Avatar
F'ing thing gas three of them.... Great suggestion
Go fast, see Elvis!
Old 10-18-2025, 10:49 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Antigravity 970ca battery, 7lbs
Electric rad fans
Aluminum brake drums
Tubular control arms
Aluminum wheels
Aluminum heads
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 10-19-2025, 09:16 AM
lakefect lakefect is offline
fiberglass doors,mine weigh 9lbs
Old 10-19-2025, 10:34 AM
And eventhough not a lot of weight that freaking pointy second hood latch I always bust my head on!
Old 10-20-2025, 12:32 PM
triathlonx13's Avatar
Replace the pot metal front grills with the plastic ones
And get some light aluminum wheels
Old 10-20-2025, 12:59 PM
R 70 Judge's Avatar
Antigravity lithium battery will get you 40-60 lbs savings depending on your current set-up
James
1970 Trans Am
