I'd like to take off 50-100lbs from our 65 GTO. I'm looking into light weight upper and lower a-arms. Any other ideas?
Treadmill twenty minutes, health rider twenty more
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
and cut back on carbs as well
Pretty sure my aftermarket 17x8” wheels are about 22lbs each. |
Aluminum block and cut down the k member
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car Last edited by mysticmissle; 10-18-2025 at 06:59 AM. |
Aluminum rear drums.
Another vote for aluminum block plus a fiberglass hood.
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
having taken the hood off and on on my 65 it is heavy! Glass hood.
Bumpers are heavy,not as heavy as my 64 impala bumpers though! As well as pot metal front grills. I think the repop grills are plastic. Glass bumpers and with "wraps" now can be as shiny as the real thing. I know my "regular" Global west tubular A arms aren't any lighter than the factory ones. Wheels can make a big difference as well as tires.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
F'ing thing gas three of them.... Great suggestion
Antigravity 970ca battery, 7lbs
Electric rad fans Aluminum brake drums Tubular control arms Aluminum wheels Aluminum heads
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
fiberglass doors,mine weigh 9lbs
And eventhough not a lot of weight that freaking pointy second hood latch I always bust my head on!
Replace the pot metal front grills with the plastic ones
And get some light aluminum wheels
Antigravity lithium battery will get you 40-60 lbs savings depending on your current set-up
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
