Old 10-20-2025, 01:24 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
Called bullet, Tim was still unavailable so I spoke to another tech. And I like his recommendation.
236/244 @ .050
582/582 lift with 1.65 rockers
112 lsa
Seems very close to the comp and just different enough. I'll be ordering it soon I think.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
  #42
Old 10-20-2025, 02:26 PM
Jay S's Avatar
Jay S Jay S is offline
236/244 @ .050
112 lsa
I was going to mention you don’t have to talk to Tim, he trained a lot of the other guys working there. That is likely the cam Tim would have picked also. It is quite a bit easier on the valve terrain than a XR236/242 comp, better valve control, and operates quieter also. It is more like the Butler custom cam but with less lift, which you really won’t miss.
  #43
Old 10-21-2025, 05:25 AM
scott70's Avatar
scott70 scott70 is offline
These are some of the questions I might have also. Pulling my motor out soon for some things and currently run a hft cam. The last one was a 60919 and showed signs of a couple of lifters that weren’t spinning correctly so I had a custom crower ground and used rhoads lifters again. If I find any of the lifters that show signs of not spinning again when I pull the motor out I will be switching to a hydraulic roller and that custom cam you just mentioned is something I might go for.
  #44
Old 10-21-2025, 10:02 AM
Steve C. Steve C. is offline
The Bullet lobes appear to be HR290/3533 and HR298/3533
https://www.bulletcams.com/Masters/HRlobes.htm
290
236
156
.3533
298
244
163
.3533
Old information here:
  #45
Old 10-21-2025, 10:25 AM
Jay S's Avatar
Many times Tim will suggest using a profile with less acceleration on the exhaust side for street longevity, that is another alteration that can be done. For instance that cam would probably look like 290/303 at .006” instead of 290/298, but the .050” spec is the same.
  #46
Old 10-21-2025, 02:21 PM
Jay's example...
Lobe HR303/3532
303
244
157
0.3532
  #47
Old 10-21-2025, 04:11 PM
Using Harland Sharp 1.65 rockers ?
If so, keep in mind their actual ratio when calculating the valve lift.
We have seen it stated the Harland Sharp Pontiac 1.65 rocker arm ratio to be 1.7, 1.72, etc.
One example. Years ago Ken Crocie used Harland Sharp 1.65 ratio rockers on a build.
The cam had 0.3600" lobe lift and based on 1.65 ratio it suggested a theoretical 0.594-inch valve lift. Yet when measured on this specific build it netted an actual 0.606-inch lift at the valve.
Here the actual ratio of the Harland Sharp rocker seems to be closer to a 1.684 ratio. This was a static measurement A running measurement 'at the valve' could be different.
  #48
Old 10-21-2025, 04:40 PM
Skippy597's Avatar
Yes I am running Harland sharps and I was expecting that. They (Harland Sharp) even told me they measure above 1.65 ratio.
I think its actually perfect with that extra boost of lift. But it's not a bad idea about the slower exhaust. I'll talk to them about it when I order it.
  #49
Old 10-21-2025, 10:23 PM
Lee's Avatar
Lee Lee is offline
Originally Posted by ponjohn View Post
What I like on the powell grind is the wide spread between intake and Ex duration.
There is another member on the forumn, cough cough Lee cough, that follows this same strategy.
Did you provide Powell with flow numbers, csa and any ther specs?
Hey, I just had a cam ground that only had an 8 degree split. Whatever it takes to make the most average power over the desired power band
Relating to this thread more directly, I recently finished up a 455/Speedmaster combo, and it has a 231/245 113lsa 110.5icl, 0.372" lobe lift HR cam.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
  #50
Old 10-22-2025, 07:45 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Is everyone still keen on the Johnson short trvel lifters?
  #51
Old 10-22-2025, 07:51 PM
Skippy597's Avatar
You had to bring up lifters. Lol
Man, I hate to admit it but I think I'm going with morels... I think. The comp evolutions still look nice but they have moved up in price.
  #52
Old 10-22-2025, 08:36 PM
JLMounce JLMounce is offline
I'm running Johnson Short Travels on my QNI lobed cam. No hint of valve float even at 6000 rpm and they are quiet.
-Jason
1969 Pontiac Firebird
The Following 2 Users Say Thank You to JLMounce For This Useful Post:
  #53
Old 12-17-2025, 10:39 AM
Skippy597's Avatar
So after being sold on doing a hydraulic roller from butler and comp evolution lifters. The budget has been getting pretty high and I already have a set of NOS johnson solid flat tappets with the edm oiling hole. So I'm thinking it might just be best to run a SFT cam.
I was looking at the crower 60311 and have rea don here a lot about it and a many guys suggest it is equivalent to a RAIV cam. I also contacted crower for a custom cam and they gave me one that's just a hair more. Here's the grinds
#00160M CUSTOM 400/455/460 PONTIAC SOLID FLAT....112 LSA 250/256@050".....348/.354 LOBE....522"/.531" GROSS W 1.5RR....B1317/B1318
Crower 60311
INT/EXH - Dur @ .050” Lift: 247°/252° RR: 1.5/1.5 Gross Lift: .505”/.517” LSA: 112°
My concern is would these cams want to run in a higher rpm than I really want to? I think I'm going to set my limit at 6000 and want to make sure I'll make good power off idle.
  #54
Old 12-17-2025, 10:49 AM
steve25 steve25 is online now
It’s a near wash.
The narrower 112 from the RA4 cam will bring down the power band while making the idle sound even more nasty.
The added duration will bring the power band back up higher.
  #55
Old 12-17-2025, 12:07 PM
Skippy597's Avatar
Noted, thanks Steve
  #56
Old 12-18-2025, 03:10 PM
Lee's Avatar
Lee Lee is offline
Note the cam in my '67, in my signature. It was a SFT from Bullet, using UltraDyne lobes. 247/247 @ 0.050, 108lsa 109icl. In the .060 over 455 I had, that motor ran best shifting at 5900rpm (and I crossed the finish line at 5700). That cam gave up 60' time, compared to the HFT 231/239 @ .050 I had previously.
If I still had the car/motor and was putting in a new SFT, I'd probably drop about 8 degrees off of the intake and spread the LSA a bit more.
The Following User Says Thank You to Lee For This Useful Post:
  #57
Old 12-18-2025, 05:41 PM
Skippy597's Avatar
Thanks Lee. That's a big move to drop off 8 degrees on the intake side from what I've read everywhere is that would put it below a hydraulic Ram Air IV grind. I'm thinking with the increased exhaust duration and wider lsa than you ran 112 vs 108 I think it will be ok??? Maybe... I'm not sure but I think I'm gonna try the custom crower SFT cam. If it's terrible I can change it later it's not a big deal or big investment compared to a roller setup. I might loose lash it a hair to give the bottom end a boost.
  #58
Old 12-18-2025, 08:35 PM
scott70's Avatar
I used to run the UD 255/263 SFT and that cam liked around 5900 shifts also. That was a nice cam.
  #59
Old 12-18-2025, 09:28 PM
Jay S's Avatar
Did Crower give you the seat timing numbers for the custom cam?
  #60
Old 12-18-2025, 10:42 PM
Skippy597's Avatar
I do not but I just sent an email and they've been great at replying
