Old 11-04-2025, 09:18 AM
67Lemons 67Lemons is offline
Default Budget build rocker arms
I’m working on a budget built 455 and need new rocker arms since I somehow misplaced the original set. Trying to avoid PRW and not spend $435 for a new set of Harland Sharp’s what are my options? It’s a street motor with an 041 cam so I can do a set of 1.5 or 1.6’s, just need to clearance the heads so there’s no rubbing with the tool from Spotts if necessary.
1972 GTO
Old 11-04-2025, 09:31 AM
78w72 78w72 is offline
Find used stockers for this type of build.
The Following 3 Users Say Thank You to 78w72 For This Useful Post:
Old 11-04-2025, 10:47 AM
performerrpm's Avatar
you could go the route of roller tip rockers, or shop around marketplace for a deal.
The Following User Says Thank You to performerrpm For This Useful Post:
Old 11-04-2025, 11:25 AM
ANDYA ANDYA is offline
Comp Cams roller tip rockers are a good compromise. I ‘ve used them in two engines with no problems.
The Following User Says Thank You to ANDYA For This Useful Post:
Old 11-04-2025, 11:55 AM
Formulas's Avatar
Formulas Formulas is offline
I could provide a good used stock set for shipping but would have to verify how many i have before commitment..
Old 11-04-2025, 03:55 PM
AG's Avatar
AG AG is online now
I have CC magnum roller tip rockers NIB 1.65 ratio if interested.
The Following User Says Thank You to AG For This Useful Post:
Old 11-04-2025, 10:16 PM
Everyone scared me away from the set that I had so I sold them, too many complaints of “blue balls”
I’ve kept my eyes peeled for a deal but haven’t seen a set of aluminum Crane’s or HS’s not that a set is really needed for this build but I’d grab them if I found them.
1972 GTO
Old 11-04-2025, 11:05 PM
Black Friday sales are coming up soon.
Buy nice new HS rockers in your preferred ratio.
It only hurts for a little while.
It’s either that or take a chance on someone’s old half-worn out used roller rockers.
A solid valvetrain makes for a reliable engine, you won’t regret it.
Old 11-04-2025, 11:19 PM
check amazon this time a year....i got a open box return on hs 1.65s last year for 125.00.....i also snagged a lunati voodoo 713 roller cam off there on clearence for a little over 200 or so
Old 11-04-2025, 11:45 PM
sdbob sdbob is offline
I snagged a 041and Hyd lifters and HS RRockers by chance talking to friends. Got another 041 and hyd lifters slightly used. Both under 150.00
The Following User Says Thank You to sdbob For This Useful Post:
Old 11-05-2025, 04:02 PM
jerry455 jerry455 is offline
I and a few other friends are using PRW Pro Series rockers, and they are doing great. My buddy who built my Pontiac, another Pontiac, 2 Fords, and a BB Chevy are all happy with them.
The Following User Says Thank You to jerry455 For This Useful Post:
Old 11-05-2025, 04:37 PM
If you decide to go with stock rockers let me know I have a couple sets of 1.5 I would part with a set.
The Following User Says Thank You to grandam1979 For This Useful Post:
