Old 12-18-2025, 08:29 PM
Boiler Boiler is offline
Default Blade terminal or button terminal on 68 Firebird Temp sender for Rally Gauges?
Most places are selling a male blade. What was on the car is the button style which has the connector slide on from the side. Which is the correct style for a 1968 Firebird with Rally Gauges?
Old 12-19-2025, 12:30 AM
Not sure on originality. I had/used the Button on my 69 birds. My 68 GTOs button, and had to use blade in a pinch.
Go with the button if you gots. Probably original.
Old 12-19-2025, 01:06 AM
Verdoro 68's Avatar
Although it's a GTO, the rally gauge sender on my car is a button as well.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 12-19-2025, 06:31 AM
I have seem both types on GM cars of the era. Ames list the blade style https://www.amesperf.com/parts/53918/ as "1967-69 CORRECT TEMP SENDING UNIT-ALL WITH RALLY OR AUXILIARY GAUGES". The button style https://www.amesperf.com/parts/63582/ is listed as "1965-72 TEMPERATURE SENDING UNIT WITH RALLY GAUGES"
Old 12-20-2025, 10:45 AM
Schurkey Schurkey is offline
Blade or button...uses the same connector on the wire. So unless you're being judged on originality, it won't make any difference so long as the sender temp range is correct.
Old 12-20-2025, 01:10 PM
burd burd is offline
Get a nOS one
