Old 12-19-2025, 05:15 PM
trishieldchief's Avatar
North and Baron
How many base 3 speed Pattern Judges do you have in your records or how many do you think were built?
Rich Johns
www.purestockauto.com
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
  #102
Old 12-19-2025, 07:12 PM
Here are some PHS' that I think could be pattern Judge, but the D.O.N. are whited out. Wondering if anyone may have a better pic or a build sheet even?
Thanks to North for most of these PHS also.
ID:	662399   Click image for larger version
ID:	662400   Click image for larger version
  #103
Old 12-19-2025, 07:23 PM
I can only remember 4 or 5 (Pattern 3spd cars) being shared in last 15 years.
But all my files are trapped.
John has 4 of them accounted.
Thinking have only seen about 3 or 4 regular 69 Judges with 3spd .
Maybe 10 or so in 70
2 or 3 in 71
71 might have a real breakdown on them. I'm not sure
  #104
Old 12-19-2025, 07:37 PM
All 3 of those were Pattern cars.
They will lose their zone order number when rebilled after some type of usage .
The first example is cut off one line too short to see it's discount code.
The other 2 have their discount code in lower left little box above dealer name = 30
All their invoice numbers start with Z (zone)
Buildsheet would be the only way to get their original zone pattern number , if their original invoices are not in PHS files.
Multi-invoice scenario
There are more out there like that.
Can remember one from Alabama , off hand.
  #105
Old 12-22-2025, 01:54 PM
pvp44 pvp44 is offline
Default PHS Docs
PHS Docs
The Following 2 Users Say Thank You to pvp44 For This Useful Post:
  #106
Old 12-22-2025, 02:17 PM
Originally Posted by pvp44 View Post
PHS Docs
Yours is Non-Pattern .
Trimmed some fat by not getting Deluxe Seatbelts or SoftRay Glass ALL.
They didn't use the Zone Pattern Order.
A dealer or customer selected the items.
Early built car though.
Probably 02A or 02B on the trim tag.
Would have GTO emblem over the heater controls originally , and no Judge emblem on glovebox.
Thanks for sharing it with us.
  #107
Old 12-22-2025, 03:42 PM
Originally Posted by trishieldchief View Post
North and Baron
Here is the breakdown of my 144 pattern invoices:
#1...3spd man no AC-0 parchment, 5 black
#2...3spd man w/AC- 0 parchment, o black
#3...4spd man no AC-25 parchment, 73 black
#4...4spd man w/AC-1 parchment, 4 black
#5...auto no AC-4 parchment, 7 black
#6...auto w/AC- 16 parchment, 8 black
Interestingly the percentage of pattern judges with a manual trans was 75.7%, non pattern Judges were 79.7% and non Judges were 41.9% so very different buying demographic between the Judge and regular GTO's.
The percentage of 3 spd manual cars was similar across all GTO and Judge models at more or less 4%.
The Following 2 Users Say Thank You to north For This Useful Post:
  #108
Old 12-22-2025, 03:54 PM
added two just now so here is an update of last chart:
Here is the breakdown of my 146 pattern invoices:
#3...4spd man no AC-26 parchment, 74 black
  #109
Old 12-22-2025, 05:41 PM
Thank you for the base 3 speed info North.
Rich Johns
1987 GN Astro Roof
  #110
Old 12-22-2025, 06:29 PM
PHS Docs
One other thing I didn't point out ,
Your invoice number starts with a { P } - PGA 489543
That means it was dealer or customer order.
Pattern Cars all start with a { Z } for Zone Order
They left off in-dash gauges with clock , remote mirror , deluxe seatbelts , SoftRay all .
Saved about $200
  #111
Old 12-22-2025, 06:40 PM
Here is a pattern Judge with some hi-lited info:
  #112
Old 12-23-2025, 01:28 AM
Yes, GTO emblem over heater controls and likely did not have glove box emblem though it did when I got it in 1998.Thanks for the info, anything else I should look for?
  #113
Old 12-23-2025, 11:34 AM
Would be good to know the build week from the trim tag.
Such as 02A 02B or etc...
Car is a little bit of a rule breaker being Non-Pattern and built that early.
We have to keep modifying with new discoveries .
  #114
Old 12-23-2025, 06:30 PM
turbo69bird's Avatar
Somewhere in here I paired about my freinds pattern judge. If you look through my histiry you’ll fin a post inthe thread about the judge w custom paint. I posted his bun tag date in there. I dint think I’ve had his PHS before. But that may help you with some info. Believe it had his options also listed.
He’s a super private guy but if I can I’ll see if I can get a copy of his PhS if he has one
960 HP @ 11 psi, 9.70 at 146.
  #115
Old 12-23-2025, 06:54 PM
Was it the 'Hangin Judge'?
If so it is in the list I have. 01 00064
Just saw in a thread you posted a cowl tag and it had a vinyl top.
That would NOT be a pattern Judge.
  #116
Old 12-23-2025, 10:23 PM
Data Plate reads 02A, thaanks
The Following User Says Thank You to pvp44 For This Useful Post:
  #117
Old 12-24-2025, 02:31 AM
Thanks for sharing the details on your car.
It still benefits North's statistics and breakdowns.
02D cars are where the glovebox emblems started being part of the package.
  #118
Old 12-24-2025, 01:34 PM
Earliest non-pattern Judges by plant (I am using VIN sequence as an indicator of build date-about 15% of my invoices have trim tag data so I can equate VIN to build week give or take a week)
A: 121385 (no trim tag but must be right on edge of 02C-02D)
B: 151XXX (oddball Canadian shipped car, not a pattern (18 options but first shipped Judge in my collection of any plant). Shipped on jan 23rd, probably 01B but no tag. I suspect it was a publicity car. Oddities include special order axle but M20 (should be M21 with special order axle), has wood wheel, exhaust tips,
B: 151729 (another Canadian shipped car, 7 options shipped jan 27th, o1B on the tag), there is another shipped to Canada car about a day or two later but with 18 options
B: 158245 (first US bound non pattern at Baltimore, feb 14, probably an 02B tag, 8 options
G: 126498 (shipping date not legible but 01C is tag date), 8 options
P: didn't produce GTO's until well after the pattern car run
R: 135694 (a convertible, shipped march 24th but trim tag date would be on line between 02A-02B), perhaps they pulled a convertible car off the line for pre-production work, Maybe to fit the new convertible wing?)
R: 141545 (shipped feb 28th, trim tag is probably 02C), 15 options
Z: 115268 (shippedjan 31st, 01D, similar to pattern but no gauges or tach but with exhaust tips, trim tag was probably 01D
Btw, I noticed something going through my listing. It seems like Judges were made in "blocks" of cars in every plant. I see clusters of 5-10 in a row and then none till the next batch. Perhaps there was an advantage to produce them like that? I would have thought the opposite because of the labor to do the stripes (perhaps that was done off the line?). Maybe what I'm seeing is really just doing cars in "blocks" of the same color?
Old 12-24-2025, 02:59 PM
Where would mine fit in being Baltimore built w/vin #130254 and 02A? Is it any more or less desirable being an early non-pattern car? Thank you all for your expertise on deciphering the PHS, I used to think I was fairly knowledgeable on these cars!
  #120
Old 12-24-2025, 03:41 PM
Yours is actually built in Framingham (G on the invoice) Massachusetts. My opinion on value is that value is driven first by condition and secondly by desirable colors and options (4spd>automatic, RAIV>RAIII etc). I think in general the Carrousel Red cars have higher value than the other colors except for maybe blue or black? I don't think most buyers assign a meaningful premium to pattern cars.
