Old 12-26-2025, 05:34 PM
Here's a thread that John V had about this tranny I think. ( the one you referred to I think)
1964 Build Sheet Codes
  #42
Old 12-27-2025, 10:26 AM
Here's a sheet that I 'corrected'. Check if it is good?
  #43
Old 12-27-2025, 01:26 PM
Looks good to me John.
Now need to update their table that lists all the option codes.
Will have to go back over it , HD Fan is one that I know is missing.
I think there are more also , HD Frame , HD Crossmember ...
  #44
Old 12-27-2025, 04:22 PM
Actually think this is correct, I was in a hurry and rewrote the close again on the '9' tranny.
See if this is better.
  #45
Old 12-27-2025, 05:52 PM
Wow you sure did.
Went right past me too.
Here are the 6 and 8 tooth gears it's talking about on the output shaft of the trannys.
John V. told me the secondary speedo gears on Fremont docs are installed on the production line.
Not at the manufacturer . fwiw
