Old 01-07-2026, 02:18 PM
nas t eh nas t eh is offline
Default 10 ply tires on a half ton.
Most of the time, I do not get very good tread wear on my vehicles.
I’ve had a number of Suburbans and Trucks over the years and they have been the worst. 5-6 years ago a friend from work told me he put 10ply tires on his 1/2ton Ford and was pleasantly surprised at how long the tread lasted.
At that time I had just purchased a new GMC 1500. I wanted to level and large tire the truck. I bought TOYO 295/60/20 Open Country AT III 10ply tires for the stock rims. They have been on the truck now for 130,000km(75,000miles) and still have 6-7/32s tread left. I have been running them at 35psi unless I’m pulling something.
This was the first Winter where I decided the the tread depth was not enough for our particularly snowy climate, so I swapped them out for Ice radials, but they will go back on the truck in the early spring as I am confident I can get another 25,000miles on them.
They have been a great all round tire, but are a little noisy on the road. I would be buying my third set of tires by now if I had made my typical choice.
Has anyone else tried/experienced this outcome with 10 ply tires?
73 T/A 455, 4speed
The Following User Says Thank You to nas t eh For This Useful Post:
Old 01-07-2026, 06:40 PM
nytrainer's Avatar
Interesting post. I do some towing with my 1500 (24’ enclosed trailer) and always thought 10 ply tires would be a good idea but was concerned the truck would ride too harsh unloaded and when not towing. Do you find that to be true?
Old 01-07-2026, 07:06 PM
muscle_collector's Avatar
i always run 10 ply on anything that they make for the size. one of my old excursions i put a set of the bfg all terrain ko2 on it back in 2011 they have around 80k on them and still have good tread but since i rarely drive it and the age they are weather cracked to the point i wont go anywhere but around town.
Old 01-07-2026, 07:18 PM
Trulyvintage's Avatar
Trulyvintage Trulyvintage is offline
Lightbulb
On my tow vehicle I run 10 ply tires
that are LT rated and have a highway
tread that is all season.
Jim
Old 01-07-2026, 08:19 PM
Nobuddy Nobuddy is offline
I run load range "E" tires. 10-ply is too soft https://www.youtube.com/watch?v=ozDDYcyrCNE
Old 01-07-2026, 08:49 PM
dataway's Avatar
dataway dataway is offline
What is the weight of a 10 ply compared to standard LT tire?
Old 01-07-2026, 09:08 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
I run the K02's on my Tacoma and so far they've been great. A little ruff riding as run at 50psi but great in the snow in MN.
Old 01-07-2026, 09:30 PM
67Lemons 67Lemons is offline
Also remember there is more tread depth on a 10 ply vs the typical all season radial so they will obviously wear and last longer with regular rotations and proper psi.
1972 GTO
Old 01-07-2026, 10:25 PM
400 4spd.'s Avatar
In winter weather I run the same tire on my Excursion. Very satisfied with wear and wet weather traction. Around April I switch to my Michelins that ride nicer but don't have the traction of the BFGs. I have two sets of factory wheels, so that makes it easier.
Old 01-07-2026, 10:59 PM
Rougher ride... increased rolling resistance.... increase suspended weight...
Longevity and durability may be a trade off for some..
Old 01-07-2026, 11:34 PM
Default The more the merrier......
That's what we do, too.
My thinking is that a tire that's rated to support 3400+ lbs will last forever when it only has to support 1500 or so.
And we've noticed that when you run over a nail with a 10-ply tire, they usually BEND rather than puncture.
Old 01-08-2026, 02:26 PM
I lower the psi to 35 when unloaded so that the tread wear is even and the ride less harsh and it helps a lot.
Also I like the firm sidewall of the 10ply tires for the less mushy feel at the steering wheel and tires are noticeably more durable regarding running over square curbs, big rocks and as someone else pointed out nails.
73 T/A 455, 4speed
Old 01-08-2026, 06:19 PM
There are no "10-ply" tires, that is an archaic term. Most LT tires are load range C or E and pretty much same weight. Quite a few are identical, the E range meets all the C requirements so they just manufacture the same tire and sell with both ratings.
Both C and E are generally about 20% heavier that the non LT tires sold for trucks and SUVs.
Old 01-08-2026, 06:48 PM
E is 10 ply
Old 01-08-2026, 09:08 PM
C are 6 ply for 1/2 ton
D are 8 ply for 3/4 ton
E are 10 ply for 1 ton
I’m archaic/ancient, so I hold onto outdated terms.
73 T/A 455, 4speed
The Following 2 Users Say Thank You to nas t eh For This Useful Post:
Old 01-09-2026, 01:10 AM
E is 10 ply
Yes. It was just some letterkenny humor about 10 ply toilet paper.
