Old 01-10-2026, 05:14 PM
slowbird's Avatar
slowbird slowbird is offline
Default Paul Knippen cnc heads
Got my set of Paul's cnc ported heads the other day and they look real nice. Short perform quite well also.
ID:	663447   Click image for larger version
ID:	663448   Click image for larger version
ID:	663449   Click image for larger version
The Following 8 Users Say Thank You to slowbird For This Useful Post:
Old 01-10-2026, 06:25 PM
opeliac opeliac is offline
I'm wondering why they dont work on narrowing the guides? My edelbrocks from All Pontiac look a lot like yours do...
Old 01-10-2026, 06:56 PM
AG's Avatar
AG AG is offline
What size is the intake opening?
Old 01-10-2026, 09:45 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Off set rockers?
Old 01-10-2026, 10:51 PM
R 70 Judge's Avatar
Mid-lift numbers are great! Hats off to Paul
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 01-10-2026, 11:44 PM
slowbird's Avatar
Originally Posted by CraigG. View Post
Off set rockers?
No standard stud mounted rockers can be used
The Following User Says Thank You to slowbird For This Useful Post:
Old 01-11-2026, 07:09 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What bore size was it test at?
Old 01-11-2026, 07:13 PM
slowbird's Avatar
4.310 I believe. I believe Paul flowed them on a 4.150 bore also and there wasn't as much of a difference as one would think.
Old 01-11-2026, 10:04 PM
FMile Pontiacs's Avatar
FMile Pontiacs FMile Pontiacs is offline
What is the cost of a new set of his heads that flow these numbers? I like the above-mentioned head.
Old 01-11-2026, 11:07 PM
CraigG.'s Avatar
Congratulations Paul - that is very impressive.
The Following User Says Thank You to CraigG. For This Useful Post:
Old 01-12-2026, 09:35 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Sometimes we do
Go fast, see Elvis!
Old 01-12-2026, 09:36 AM
PAUL K's Avatar
Close to 2.4 tall
Go fast, see Elvis!
Old 01-12-2026, 09:38 AM
PAUL K's Avatar
Port work is $1500
Go fast, see Elvis!
Old 01-12-2026, 09:51 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Nice work Paul! I may have to send you my Hi Ports.
69 Firebird - Angry Bird
455 with 84mm Torqstorm
The Following User Says Thank You to Nacs Fab For This Useful Post:
Old 01-12-2026, 06:59 PM
ponjohn's Avatar
Port work is $1500
Do you have 4.150 flow numbers?
Old 01-12-2026, 07:26 PM
PAUL K's Avatar
Yes.... It was over 350 with a 2.11 valve
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 01-12-2026, 08:31 PM
blueghoast's Avatar
Impressive.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
Old 01-13-2026, 09:48 AM
Jim Moshier's Avatar
Very Nice work Paul.These should make some good power!
Jim Moshier
1962 Catalina 389
The Following 2 Users Say Thank You to Jim Moshier For This Useful Post:
Old 01-13-2026, 07:38 PM
ponjohn's Avatar
Start with 72 cc head?
Old 01-14-2026, 09:11 AM
performerrpm's Avatar
Port work is $1500
i have a set of disassembled 72s on the shelf along with a victor 4500efi ive been reserving for you to do your port work on....soon as i get back on track with my ia2 build
The Following User Says Thank You to performerrpm For This Useful Post:
