Old 01-29-2026, 10:24 PM
Lamans63 Lamans63 is offline
Question 63 La Mans
63 La Mans Retirement project.
I got a great deal on a 63 La Mans. I also got two 301 motors, one already built. a 68 frame with the transmission disk brakes ectara. Every thing for $2500.00.
I'm new to this forum and looking for some advice. If anyone is interested, I also have the original 326 motor still in the vehicle.
Old 01-30-2026, 12:16 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Is it somehow related to a Pontiac LeMans?
Sorry... I just couldn't resist...
The Following 2 Users Say Thank You to Jack Gifford For This Useful Post:
Old 01-30-2026, 12:53 AM
R 70 Judge's Avatar
Unless you are restoring, I’d just stick a 400 in it. Are using the original IRS and rope shaft, or converting to a solid axle?
James
1970 Trans Am
Old 01-30-2026, 06:51 AM
Welcome to the forums!
The 301 might not be the best choice, but will work. The motor mounts might be a problem unless adapters used. The 400 as said would be a slam dunk.
Old 01-30-2026, 08:05 AM
Cerberus's Avatar
Cerberus Cerberus is offline
Lamnas? Is that you?
The Following User Says Thank You to Cerberus For This Useful Post:
Old 01-30-2026, 09:51 AM
Radman's Avatar
Radman Radman is offline
A 63LeMans came with 3 engine choices. single barrel carb 4 cylinder had 110HP. The 4 barrel 4 cylinder had 166HP. And the quote 326 was not a 326 it was in fact the 331 8 that Pontiac made for the GMC trucks at the time. I am the vice-president of the Little Indians chapter of the POCI. you can contact us at Littleindians.com our club is dedicated to the 61 to 63 Tempest and LeMans cars.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 01-30-2026, 10:51 AM
Steve C. Steve C. is offline
Might be of interest....
1963 lemans rear change over
https://forums.maxperformanceinc.com...d.php?t=427230
Old information here:
Old 02-01-2026, 09:50 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
If your the president of the little Indians chapter you know the 326 was a 336 not a 331.
The Following User Says Thank You to hobbygto65 For This Useful Post:
