Old 01-30-2026, 06:24 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
Default Larger sway bar hits coils
1966 lemans with 1" taller springs. I bought a larger Fbody sway bar and I installed it but it slightly touches the coils. I installed rivnuts in the frame slightly forward to clear the steering and it's not touching but it literally couldn't be any closer. Should I just switch back to the stock bar?
ID:	664371   Click image for larger version
ID:	664372   Click image for larger version
ID:	664373   Click image for larger version
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
Old 01-30-2026, 06:32 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Is the car in the air or is the weight on the suspension? Looking at your shocks they're not centered in the springs. It's hard to see but it almost looks like the springs aren't setting in the cups right.
67 Firebird Convertible
The Following User Says Thank You to jwcfbd For This Useful Post:
Old 01-30-2026, 06:38 PM
That is the same thing that jumped out at me, it looks like the springs are not centered in the spring pockets.
Old 01-30-2026, 07:32 PM
Skippy597's Avatar
Yeah they seem to be sitting in the cups I've checked but man they were a bear to get in. It's possible their not sitting right I just though it might be from being a longer coil. And yes weight on wheels in these pictures.
Old 01-30-2026, 11:41 PM
jwcfbd's Avatar
Make sure the end of spring is aligned with the detent in the cup. Not the best picture but you get the idea.
Old 02-16-2026, 01:08 PM
jwcfbd's Avatar
Have you been able to figure out the problem?
Old 03-31-2026, 09:20 PM
Skippy597's Avatar
Yes, in fact just this last weekend. Like you fine gentlemen suggested the coils were not completely in their pockets. That solved the spring rubbing issue, but it was still too close to the idler arm. So I upsized and moved the front holes slightly and installed 3/8 rivnuts. Now have about a 1/4 clearance.
The Following User Says Thank You to Skippy597 For This Useful Post:
