Old 01-20-2026, 06:42 PM
punkin punkin is offline
Default Coolant
Good day everyone,
I'm replacing a heater core on my 69 f-body project. I have aluminum heads, intake and radiator and just realized that the heater core is copper. Curious to hear recommendations for coolant type with a mix of these metal types.
I'm trying to take in a lot of technical information but I haven't seen anything that directly addresses this question but I think HOAT looks like it might work.
I appreciate your recommendations.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
Northwind (Induction undetermined)
3.50:1 Rear
Old 01-20-2026, 11:16 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
When I had my 400 built using aluminum heads, intake, radiator and bored out to a 461 pushing 550hp. When I asked the shop what to use they told me I was fine to just use the regular premixed stuff.
67 Firebird Convertible
The Following User Says Thank You to jwcfbd For This Useful Post:
Old 01-21-2026, 05:06 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
From what I understand, as long as you dont have any copper/brass you can use the newer stuff. But if you have an original heater core.
HOWEVER, you need to be completely flushed as new and old dont mix well.
I wanted to use newer stuff, just because I hate the old green toxic stuff. But I split the difference and went with Peak Sierra. Its Poly Glycol instead of ethelene glycol so its safer for pets and whatnot.
I hear its big in the offroad community so if you have a leak in the woods you arent mudering wildlife.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 01-21-2026, 06:02 PM
jerry455 jerry455 is offline
I like using the orange Dexcool antifreeze. That is what I have seen a lot of engine builders use lately. GM has been using it since around 1995-1996. There is no good antifreeze for wildlife as even propylene glycol is still just as poisonous. Instead of taking a cup of ethylene glycol to kill you, it takes a cup and a half of propylene glycol.
The Following User Says Thank You to jerry455 For This Useful Post:
Old 01-22-2026, 07:41 PM
I thank you for the replies and suggestions.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
3.50:1 Rear
Old 01-22-2026, 08:42 PM
tom s tom s is offline
I use distilled water and a bottle of water wetter.Nothing else.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 01-23-2026, 10:24 AM
78w72 78w72 is offline
You can do that in warm weather states... not in colder climates.
Standard green stuff works great for copper/brass parts as well as aluminum, been using it in cars with different combos of those metals for decades with no cooling system issues, parts & radiators show no signs of corrosion or pitting etc.
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
Old 01-24-2026, 06:06 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Default check these guys out
https://norosion.com/
I had a 10 deree improvement in the worse part of summer over coolant.
Karl
The Following User Says Thank You to 72LuxuryLeMansLa. For This Useful Post:
Old 01-24-2026, 07:17 PM
dataway's Avatar
dataway dataway is offline
propylene glycol is actually very safe. It's a common ingredient in food, drugs etc.
Old 01-29-2026, 06:36 PM
Yeah, thats what I was thinking too, but I didnt feel like arguing.
It is worse as a coolant from a heat dissipation standpoint from what I understand. But Im only mixing mine like 1:5. My garage rarely gets below freezing so I only need protection down to about 20 degrees
Old 01-29-2026, 06:56 PM
burd burd is offline
My 95 w/ alum engine, rad, reg heater core, green. Stuff. Factory.
Keep your Jeep,out of the woods.
Old 01-30-2026, 03:21 AM
dataway's Avatar
Isn't the Zerex recommended for vintage cars? Like the Zerex Green or the G08?
Old 01-31-2026, 01:31 AM
LM93 LM93 is offline
Zerex Original green is IAT tech with a 5 five year/ 150k mile life, perfect for cars with older brass radiators or heater cores. If your parts are new then G05 might be a better choice, in theory HOAT stuff is easier on water pump seals than IATs. I believe IATs work by creating a layer of protection on the surface of metals and HOATs work by cleaning oxidation as it forms. Regardless, change your antifreeze when the jug says so, it's not expensive to do. A big factor in antifreeze tech is that OEMs can't trust their customers to not use tap water so, for example, European OEMs formulate their antifreeze specs to work with the hard water that is common over there.
Old 01-31-2026, 08:40 PM
vertigto's Avatar
vertigto vertigto is offline
So what about stock-ish engines with aluminum water pumps and radiator?
Old 02-01-2026, 10:38 AM
https://www.walmart.com/ip/Prestone-...SABEgLYg_D_BwE
https://www.walmart.com/ip/Super-Tec...=0&athena=true
Old 02-01-2026, 02:52 PM
Red Box Rebel Red Box Rebel is offline
Wink Texas January FREEZE
Texas is a warm weather state and actually, it is downright hot as hell in the Summer with 100+ days more than 30 last few Summers. Woke up every morning this past week here in San Antonio to temps between 20F and 25f every day.
Point is that even in so called warm weather states, freeze protection is still required.
In addition to freeze protection, you need to guard against corrosion from running just water.
The Water Wetter product helps reduce coolant temps but will not protect against corrosion and freezing temperatures. Go with a minimum of 40% coolant/anti-freeze product.
Prestone has recently produced an Anti-Freeze fluid that will last 350k miles and 15 years for all years and all makes of cars and trucks. I use it in my '68 GTO with standard heater core and cast-iron block/heads and an aftermarket aluminum radiator. That is what I would use in your project.
Old 02-01-2026, 03:20 PM
This does. https://norosion.com/
https://norosion.com/tech_coolant.htm
Karl
Old 02-02-2026, 10:18 AM
This is a better water wetter type product that does have anti corrosion properties, but no anti freeze. You can use a lower concentration than 40% of antifreeze for warmer climates to protect to ~20f. The anti freeze products also have boil protection too, so best to use some percentage for both benefits. The hypercool product works just as good as water wetter for reducing temps but also has anti corrosion for guys that want to or can run pure water or a low mix of coolant.
https://www.walmart.com/ip/Hy-Per-Lu...SABEgJlKvD_BwE
Old 02-02-2026, 01:55 PM
I have used Prestone for years and years, never had a problem, even with cars that sat for a while. All have a mix of iron, aluminum, and brass.
Once I get the GTO ironed out and am sure I won't be breaking into the engine any time soon, I will probably switch to a HOAT, just so I don't have to change it every X years. I think they now go to 100k miles/10 years.
Old 02-05-2026, 05:05 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
I just use 50/50 conventional green, and make sure the label states that it conforms to GM 1099-T standards. Zerex, Napa, etc. all work.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post:
