Old 02-02-2026, 05:30 PM
Terry M. Hunt Terry M. Hunt is offline
Default ID this carb
Bought a 66 Tri power intake and carbs many years ago. Now taking a shot at figuring out exactly what I wound up with. Photos below show the center carb that was on the intake. Only two numbers I can find on it are 7037688 on the bowl and 31892 cast into the bottom of the base plate. I have owned Tri power cars since 1977, so I’m somewhat familiar with the setups, but I’m no expert. Much of this carb looks familiar, but the base plate seems weird. I realize it could be a Frankenstein version somebody cobbled together. Can anybody offer any insight as to what this thing is?
ID:	664508   Click image for larger version
ID:	664509   Click image for larger version
ID:	664510   Click image for larger version
ID:	664511   Click image for larger version
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 02-02-2026, 05:47 PM
Edit: discovered more numbers stamped into choke side of the bowl as follows:
7029104
2 CB91
Terry Hunt
Old 02-03-2026, 07:51 AM
Kenth's Avatar
Kenth Kenth is online now
Bowl 7029104 is 1969 Chevy 327, air horn has cast # inside, idle vent cover is a Chevy thing.
Throttle plate looks legit, wrong style idle needles though.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-03-2026, 03:58 PM
unruhjonny's Avatar
I decided to look this one up in the 1969 Rochester book;
Curiously in the index, this application number isn't listed, but it is shown on the 327-2bbl page shared with the following application numbers;
7029127 (manual trans/standard)
7029129 (manual trans/air cond)
7029102 (automatic trans/standard)
7029104 (automatic trans/air cond)
1970 Formula 400
Old 02-04-2026, 04:00 PM
Kenth's Avatar
7029104 is indexed in all mine 60´s, 70´s and 80´s #9 Delco manuals.
ID:	664622   Click image for larger version
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-04-2026, 04:40 PM
Well I was pretty sure this was not correct for this set up, so I’ll see if I can send it down the road to some Chevy guy. Thanks for helping me figure out the original application on this
Terry Hunt
Old 02-04-2026, 10:27 PM
Joe Joe is offline
Would be interested in the carb if you're going to send it down the road. Let me know. Thanks Joe
Old 02-05-2026, 08:12 AM
Kenth's Avatar
With Pontiac throttle plate and (Pontiac?) airhorn it´s not a Chevy carb either, more like a "Frankencarb."
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-05-2026, 05:23 PM
unruhjonny's Avatar
/\ and these days, most are!
1970 Formula 400
Old 02-06-2026, 05:01 PM
Joe, you have a PM
Terry Hunt
Old 02-07-2026, 06:44 AM
Joe Joe is offline
Terry, PM returned last night. Thank you Joe
