Old 02-11-2026, 01:26 PM
LarBear LarBear is offline
Default 1963 Tempest Build
Hi fellas,
Been a long time since I had a major project. Looking for pictures, advice, and options for the 61-63 front suspension. Over the years I have watched a lot of fast Little Indians rip down the 1/4 mile! With no aftermarket what have members done.
Build is a 4 link rear suspension and looking to retain as much body structure as possible.
Old 02-11-2026, 02:03 PM
R 70 Judge's Avatar
Welcome to the board! Here's what I did with my 63 back when it was being built. It actually worked pretty well. I believe Dave Johnson went high 8's with a stock steering set-up.
https://forums.maxperformanceinc.com...ht=rack+pinion
James
1970 Trans Am
Old 02-11-2026, 05:40 PM
sdbob sdbob is offline
R70 Judge what master cylinder did you use? I like the ports towards the inner fender. I'm using front discs from guy on here forgot his name,duh.
Old 02-11-2026, 08:31 PM
R 70 Judge's Avatar
I searched through my old posts and found this list
2)Earl's#63010114 flex line
2)Earl's#961603 pipe to AN adapter
2)Earl's#989543 tubing adapter
10) Mr. Gasket#4311 studs
1)Strange Engineering#B3359 master cyl.
1)Wilwood#140-0261B brake kit
IIRC The disc brake brackets were from 63Longtop here on PY
James
1970 Trans Am
Old 02-12-2026, 02:30 PM
KGTO's Avatar
KGTO KGTO is offline
Hi there, welcome
You may want to look for TwoOldGoats on here. He runs one, I sold him my blower/intake set up and he runs in the 7s I believe.
That may help too
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 02-12-2026, 07:08 PM
Finally brain remembered, Scarebird s parts.
