Old 12-20-2010, 07:32 AM
Tim john Tim john is offline
Default HURST Wheels for sale.
Good morning gang.
I have three sets of original HURST wheels that I am offering up for sale.
The first set is a sequential numbers matching set of four thick shank, non-webbed and factory original 5 on 4 3/4 bolt pattern which is correct for our GTO's. These are 100 % original and never had any work preformed on them in reference to restoration or polishing. They do accept the reproduction trim rings and retaining spring clips (readily available) and I have originals of both if needed. These four wheels are arrow straight and are the earliest date coded ones I have ever seen, they are all 1964 dated. $ 3,500.00 for the set of four wheel will put them under your Christmas tree.
The second set of original HURST wheels are a date & numbers matching set of five wheels, four are sequentialy numbered and the fifth is correct in every way but out of number sequence only. They are all thick shank and webbed and accept the reproduction trim rings and spring retaining clips (I have both available). This set of five wheels are completely restored and will compliment the finest restoration. I have well over 200 hours into restoring this set of wheels, they are brilliant, blinding and outright dazzling. I have been restoring these rare gems for several years now and have a very sucessful process but it takes a lot of time, there are no short cuts. I take great pride in what I do and accomplish and there will be no disapointments. For this set of five wheels I would like $ 5,000.00.
I have one more set of numbers matching of thick shank and webbed, these are the Ford / Mopar bolt pattern (5 on 4 1/2). All matching but one of the wheels has a pitted steel rim section, three are real nice and one is pitted for some reason ? It is not an integrity issue at all but an accurate description. Once restored the trim ring covers the steel rim portion and it will appear as nice as the rest of them. I would like $ 1,000.00 for this set of four matching wheels.
Shippping will be the responsibility of the buyer but rest assured they will be packaged very well protected and arrive to you as such. I have owned well over 50 original HURST wheels and know them well, they are exactly as I have mentioned and are well above the average quality you see out there. So here is an opportuinty to slip a set of fine jewlery on your car for a spring reveal.
As a side note, I can restore the first set if someone wanted them done but it would be spring time before I could have them finished. I also have several original trim rings, one set of NOS thick shank lug nuts, a few original center flat caps, 100 + NOS original trim ring retaining spring clips.
Well, there you have it, a few different options and opportunities to install a set of the most desirable wheels ever manufactured for our beloved Pontiac's.
Tim john---
Old 12-20-2010, 10:57 AM
The edit button has gone away for some reason. I made an error in asking price for the first set of original, un-restored set. $ 3,000.00 is what I intended to write not the posted $ 3,500.00. Thank You.
Tim john---
Old 12-21-2010, 10:05 PM
ALLGM ALLGM is offline
PM SENT
Old 12-22-2010, 06:56 AM
PM answered.
Tim
Old 01-27-2016, 12:27 AM
bill ryder's Avatar
bill ryder bill ryder is online now
Do you still have any sets of hurst wheels for sale? Thanks!! "Bill"!
Old 01-28-2016, 10:29 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default clips
Interested in lug nuts and retaining spring clips. Have 8 wheels so how many clips do I need? Price and how do you want paid? Thanks
Old 01-28-2016, 11:04 AM
Ram4king's Avatar
Ram4king Ram4king is offline
Are you guys aware this ad is 6 years old?
Old 01-28-2016, 01:00 PM
c5farmer's Avatar
Default Duh!
Never thought to look at the posting date. Thanks
Old 01-28-2016, 04:03 PM
bill ryder's Avatar
Yep. I am aware. Never hurts to try!!!! "Bill"!
Old 02-09-2026, 01:11 PM
Hurst Wheels Hurst Wheels is offline
Default Restoring Hurst Wheels
Tim, I'm looking to tackle restoring a set of Hurst Wheels and seen one of you earlier post and I'm looking for some advice. Also do you know of any 5 X 5 Hurst wheels for sale ?
Thanks in advance Bill....
Old 02-09-2026, 10:25 PM
stl67 stl67 is offline
Good luck,
Sent tIm John $450 bucks for a set of trim rings several years ago, after multiple messages he ghosted me and never heard from him again
Says "Thief" to me
Beware
Old 02-15-2026, 11:18 PM
Yeah, I know the thread is really old, but it don't hurt to try....
Old 02-16-2026, 12:26 AM
Best off placing your own ‘parts wanted’ ad in the appropriate classified forum.
