Old 02-15-2026, 10:54 PM
Default What's worth keeping?
I parted out a lot of cars in the 1980s to mid-1990s at a time when I had a fair amount of free and cheap storage space. I lost some of the storage space about 12 years ago and downsized in a hurry, scrapping a lot of stuff. I'm getting ready to downsize again, and I'm wondering if there is any demand for the more common stuff beyond the scrap value. Here is a partial list of some of the stuff.
- 4X heads with press-in studs, mostly 455 but some 400 sets
- 66 and 7M5 heads
- 1970 #15 heads (455 360HP)
- 1969 #46 heads (428 360HP)
- 6H heads (1976 455)
- Point style distributors from run of the mill cars, maybe a few from XH coded GP motors
- 3/4 and full windage trays
- 1958 - 1962 early forged rods
- 1973 - 1978 cast iron Q-jet intakes
I suspect that shipping costs on heads makes them pretty much worthless, but I wanted to check before I started hauling stuff off.
Old 02-15-2026, 11:59 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Generally the 70 15 heads, 4X 400 heads and windage trays are good movers
Go fast, see Elvis!
Old 02-16-2026, 12:21 AM
The 1969 #46 heads are nice for 350 builds. Points distributors in good condition can be sold for a few bucks if you’re wanting to put in the effort. Early forged rods might have some takers but again it takes time and effort to move them.
Besides the items that Paul has mentioned scrap it all or give it away locally to a Pontiac guy.
Shipping is a killer so unless someone local wants the heads and intakes…..almost nobody’s buying.
Old 02-16-2026, 12:41 PM
Thanks for the reply.
I ran a craigslist ad for the 46s & 15s last year for $100, had a few replies but shipping was too high and it wasn't worth the drive. I also ran a listing for a number of the points style distributors for $20 each, had no interest.
I was thinking about removing the valves from the 400 & 455 heads and saving them, but I'm not even sure if that is worth the effort. Most of those were pulled in the 80s and have never had a valve job done on them.
Mike
Old 02-16-2026, 01:06 PM
Old used 2-piece factory valves can fail and unless you’re willing to take the chance or are really bucks down they belong in the scrap heap along with the heads.
Old 02-16-2026, 04:13 PM
Good point on the valves. I was thinking that valves might be hard to find at some point, and they might be worth saving.
Old 02-19-2026, 03:18 PM
Do a single ad on the 1970 #15 heads.
Hype the 87cc chamber in the headline.
Eventually they will sell locally , I suppose.
Old 02-19-2026, 03:20 PM
Mike I think my brother needs a (B) date range 1978 intake if you have one .
Old 04-23-2026, 05:37 PM
Default Your message folder is FULL
Mike: Tried to reply to your PM, but your message folder says 'FULL'
Old 04-23-2026, 07:12 PM
burd burd is offline
I scrapped some 6x heads. Scrap is with the trip.
Old 04-23-2026, 07:54 PM
I have been trying to get rid of some good used parts for FREE and have had no takers. 1 item is a set of forged 421 OS or 428 standard pistons with less than 5K miles on them. I only removed them because I super charged the engine.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 04-23-2026, 08:21 PM
I don't think I saved any intakes with restricted secondaries, unless they are with a complete engine. I think I have a 1975 WT and a 1976 WX. I had a PWH motor but I sold it complete many years ago.
I did something stupid and hurt my leg about six weeks ago. I've been somewhat out of commission since then, but getting better.
Old 04-23-2026, 08:29 PM
400 4spd.'s Avatar
Asking in general, would any of those heads do well on a .030 over 428? It currently has 670's on it as built (never fired).
Old 04-23-2026, 08:57 PM
Red face
I needed to know that 4 months ago. Not needed now.
Old 04-23-2026, 11:04 PM
15's work well on a 428. They are 1970 455 4-barrel 360HP heads. The most desirable 1970 455 heads are the 64's, which come on 370HP 455 engines. A set of 15's will give you a little about 9.2 to 1 compression ratio, if I remember correctly. The drawback is they have pressed-in studs.
I sold the set of 15's locally for $100.
Mike
Old 04-24-2026, 08:08 AM
muscle_collector's Avatar
ive got a bunch of this stuff also. im at the point to where i am sick of dealing with people who just want to talk or come over to hang out.
if anyone needs those 64 heads let me know i have a few sets of them. will sell them cheap.
Old 04-24-2026, 04:01 PM
400 4spd.'s Avatar
I tried to PM, but your inbox is full.
Old 04-24-2026, 10:04 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Goatracer1, you have a PM.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 04-25-2026, 07:15 AM
scott70's Avatar
scott70 scott70 is offline
Mike
The other drawback is they’re small valves compared to the 64s but I believe you can add the big valves with a little work
Old 04-25-2026, 11:08 AM
SD455DJ SD455DJ is offline
I’ve used stock small valve 1970 #15 heads on a YH 455 build that made 390 hp through log exhaust manifolds, stock cast iron intake & q-jet carb. It has a Summit 2802 cam. We had the press-in rocker studs pinned rather than converting to screw-in studs. They have been fine for 5 years of street use with no pull-out issues. The valve springs have 120 lbs. seat pressure and 270-280 lbs. at full lift (.466”/.488”), so relatively soft. After a minimal cutting to true up the deck surface the chambers measured 90-91 cc’s and 9.94 to 1 compression on the .040” over 455 (464). We used Ferrera 1-piece stainless steel street valves (1.96”/1.66”).
The stock small valve heads flow around 195/150 cfm at .450” lift that the 2802 cam provides. It’s an easy 400 hp/520 lb.-ft. engine with RA manifolds, a little more with headers. I believe Stan has various 1970 #15 heads on his head flow list that had 2.11”/1.77” valves installed that flowed as much as any other stock large valve head of the time (12, 13, 16, 62, 64, etc.) around 210/160 cfm.
Rocky Rotella wrote an article for HPP magazine years ago flow testing stock 455 #15 heads and then again after converting to 2.11” and 1.77” valves. I believe these are on Stan’s list.
I think these are good heads to keep/sell/reuse/convert to large valves.
Dennis
Name:	15 w Head Gasket.jpg
ID:	668787   Click image for larger version
Name:	70 YH 455 Dyno.jpg
ID:	668788   Click image for larger version
Name:	70 455 Q-jet Dyno.JPG
