Hello PY'ers.
I had a good week testing two of my engines on the dyno. One is for myself to install in a 1974 Formula 455, the other is for my friend for his 1964 Tri-Power 4 speed GTO. Thought to share the information for the enthusiasts and builders out there. Formula engine.. 455 based (465 ci) 485428 block. .040 over. 24.5 CC dish Butler/Ross pistons. Eagle 6.625 rods. 103 Crank. Dan Barton 70 CC early RP Edelbrocks 2.200/1.650 valves. 10.2:1 CR. Old Faithful V1 cam. HS 1.65 rockers. Comp 857 HR lifters. Port matched KRE Northwind, BG 850 downleg Mighty Demon, Hooker 4202. 91 octane. 600HP at 5800 and 590 TQ at 4900-5000. GTO engine.. 455 based (467 ci). 485428 block. .030 over. 6cc relief Butler/Ross pistons. Eagle 6.800 rods. Eagle cast steel 4.250 Crank. My hand ported 87 CC RP Edelbrocks 2.110/1.660 valves. 10.4:1 CR. Butler HR 230/236 112 LSA cam. Scorpion 1.65 endurance rockers. Lunati (Morel) HR lifters. KRE Trade-Wind w/ 3 2BBL Holleys. Hooker 4202. 91 octane. 545 HP at 5600-5700 and 550 TQ at 4300. I think they turned out great, ran like champions with no leaks or issues to speak of. Lots of interesting discoveries along the way as always. Ask away if any interest. Last attachment shows overlay of the 4 engines tested over the last year. All of them turned out really well, and shows how easy it is to make respectable power out of this venerable engine. Last edited by ChiefCrazyCanuck; 02-13-2026 at 10:41 PM. |
| The Following 5 Users Say Thank You to ChiefCrazyCanuck For This Useful Post: | ||
Knocking them out! Very nice builds and results!
Keep up the good work! |
Very nice engines and results. Excellent torque numbers and the power is where it can be used all the time in a street car. First results I have seen on the KRE intake with tri-power.
Thanks Paul!
| The Following User Says Thank You to ChiefCrazyCanuck For This Useful Post: | ||
Thank you sir! The Trade-Wind is a cool part that backs up it's looks with performance.
Very nice results. I have added them both to the Pontiac N/A Pump Gas List in the Dyno Engine Section
http://www.magneticlynx.com/carfor/pont_gas.htm Stan
Really nice builds, congrats. I'm real interested in track results if you guys go.
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
Thank you, I do plan to run my Formula but it will be a way off. Will report back when it takes place.
Impressive numbers. Good job
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Very nice Travis. The Formula engine did a bit better than my KRE D port heads. I run the Torker 2 with road paver 246/252 with 1.5 Rockers. 589 hp/600 T. I'm running Crower solid rollers on that cam.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
Thanks Charles, and good to see how fast you all are running now with the '68!
Great results.
What do you think the heads flowed on the 465? |
Good question! 336 at .500 and flat from there on up. That flow level at a moderate valve lift without a gigantic port all add up.
The bigger intake valve (2.200), and the port work/valve job, contributed to the extra power output I am sure vs. the engines I had tested earlier. There were many great takeaways from these builds. |
Travis, Impressive numbers. Good job
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
what do think the numbers would be on the 455 built for the GTO if run through ram air exhaust vs headers?
I would say down around 30 HP. And for the average guy driving it around you would never know the difference. Assuming an aftermarket RA exhaust casting with the big exit. Just my guess. Of equal importance is the exhaust system behind the manifold or header. We drive these things. |
Nice that 465ci made some HP damn, 336cfm @.500 is nice, Old Faithful V1 cam = 236 / 242 cam?
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
