Old 02-18-2026, 12:32 PM
64-389's Avatar
64-389 64-389 is offline
Default '64 Hood Scoop Hardware
I've recently acquired a GTO hood and scoops for my 64 LeMans. But there was no hardware for the scoops. They're painted (thankfully!), but there's no bolts.
I read on here that they might be studs with a nut at the bottom? I just checked the Ames catalog and didn't see where you could just order the hardware.
Does anyone know what exactly I need and/or where to get it?
The scoops I have appear to have threaded holes. Not sure if I could just do a bolt?
Thanks!
Tom
1964 GTO Custom Convertible
Old 02-18-2026, 02:48 PM
1_Wild_Cat's Avatar
1_Wild_Cat 1_Wild_Cat is online now
Factory hood scoops used studs with nuts that had attached washers that look like spurs (for riding horses - I don't know the name of that type of washer). They also used some kind of sealant (seam sealer maybe) around the perimeter. I can post a picture if that would be helpful.
Not sure where to buy the hardware. Maybe AMK?
Old 02-18-2026, 10:34 PM
jhnichols2 jhnichols2 is offline
Here is a picture of one (not to scale). I can get some measurements if you want more information.
Old 02-19-2026, 12:30 PM
64-389's Avatar
Thanks for the replies! Looks like coarse thread for sure. I think I might get some bolts and put a nut about halfway down. Especially if I can't find the exact piece. I would take some measurements please, especially for total length. I can probably take a scoop into the hardware and find the right width.
Tom
Old 02-22-2026, 03:16 PM
Seems to be a 10x20x5/8, or possibly 10x24x5/8.Nut is 3/8.
ID:	665317   Click image for larger version
ID:	665318   Click image for larger version
ID:	665319   Click image for larger version
ID:	665320   Click image for larger version
Old 02-23-2026, 11:21 AM
64-389's Avatar
Perfect, thank you!!
Tom
Old 02-23-2026, 01:57 PM
Dick Boneske's Avatar
They are 10-24 studs with hex nuts and the washers pictured. Nothing special.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-23-2026, 03:44 PM
tempest1964's Avatar
I always referred to those washers as starlock washers. Either internal or external.
Old 03-03-2026, 12:56 PM
64-389's Avatar
I found some 10x24 bolts in my garage and cut them down to size. I don't have the right washers yet, but I installed them for now. Looks good! Thanks again.
Name:	Scoop Hardware.jpg
ID:	665801   Click image for larger version
Tom
