Old 03-02-2026, 01:43 PM
Goatboyjohnny Goatboyjohnny is offline
Smile Which clutch pushrod
Hi guys, been awhile for an update on my 66. I'll have to put some pics on my Original thread. My latest issue involves the clutch pushrod. I finally bolted a driver seat in, and when I pressed the cluthch pedal in, there was little to no resistance.. long story short, the end of the threaded rod had snapped off at some point. Nothing surprises me any more. My question is which of the 2 styles is more correct, and is one design superior to the other.?. My setup is all stock. I was using the rod in the second pic. As always thanks for any input.
Name:	Screenshot_20260302_112052_Samsung Internet.jpg
ID:	665718   Click image for larger version
Name:	Screenshot_20260302_112104_Samsung Internet.jpg
Old 03-02-2026, 02:57 PM
Mr. G Mr. G is offline
The rod in the first pic is shorter so if you were using the one in the second pic and it worked then that is the one I would use.
Old 03-02-2026, 05:30 PM
SR-71 SR-71 is offline
If everything is still stock, then go with the first one which is correct for your application. The original push rod didn't make a hole in the clutch fork did it?
The Following User Says Thank You to SR-71 For This Useful Post:
Old 03-02-2026, 07:20 PM
JSuchma JSuchma is online now
I have a few of the correct NOS ones left, along with the anti-rattle spring, if needed. Your first pic is the correct style. Send me a PM if you want to go that route.
Old 03-02-2026, 07:31 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
PM sent
Old 03-02-2026, 08:23 PM
Didn't put a hole in the clutch fork. I've never even had my foot on the pedal. The broken piece is AWOL too, was probably laying in the plastic sheeting I had the undercarriage masked off with. I guess my good fortune is that I noticed it, and didn't try to put it in gear. Thanks for the input everyone!
Old 03-03-2026, 09:03 AM
Andre's Avatar
Andre Andre is offline
I personally prefer the 2nd one shown. The ones I have were from GM and very strong.
Old 03-12-2026, 10:49 AM
64-3Deuces's Avatar
Tried to reply to your PM--Your mail box is full
Old 03-12-2026, 05:55 PM
Please resend, as I just finished some inbox cleaning.
