Old 03-18-2026, 02:53 PM
proximity_alrt's Avatar
proximity_alrt proximity_alrt is offline
Default Drunken Emblem Installs?
So I've been on the lookout for a 69 Lemans or GTO as of late and have come across two glaring emblem installs that are just...wildly awful. I'm not sure what is going on here. The Lemans logo isn't even centered on peak of the fender, and then the GTO emblems are crazy crooked. I didn't even know you could bend that pot metal on the trunk lid emblem without breaking it like that. The GTO even says it's "Fully Restored" whatever that means.
How could you not care enough to get it anywhere near right? Or am I just hitting that age where the world is straight and I'm the sideways one?
ID:	666513   Click image for larger version
ID:	666514   Click image for larger version
ID:	666515   Click image for larger version
The Following User Says Thank You to proximity_alrt For This Useful Post:
Old 03-18-2026, 02:56 PM
OG68 OG68 is offline
I've seen the 69 GTO fender emblem a bit off on a number of cars including 68s. So much so, I wonder if there was defective press at one of the Fisher Body plants.
Old 03-18-2026, 02:59 PM
Another shot of the LeMans.
Old 03-18-2026, 03:33 PM
That one is just pathetic
Old 03-18-2026, 08:13 PM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
I put some new GTO badges on my front fenders years ago and they were crooked. I found the studs on the back of the badges were not in the correct position. End up using one stud only and removing the other and using double sided tape to hold in position, been over 10 years now and they haven't moved.
Your car must be very fast !
Because you were haulin ass when I passed you in my GTO.
Old 03-18-2026, 08:36 PM
PAUL K's Avatar
PAUL K PAUL K is offline
My Super Duty Formula came with a Formula 350 emblem on the passenger side. However it was installed in the correct location and level. It makes for a good confirmation with the "all original" crowd for what to do when the car is restored.
Go fast, see Elvis!
Old 03-19-2026, 07:53 AM
Most folks here get the emblem & decal install real good.
Old 03-19-2026, 09:30 AM
burd burd is offline
Something hit it.
Old 03-19-2026, 01:13 PM
unruhjonny's Avatar
I've read you mention this before:
That was a production line error which in theory was supposed to have been caught at either:
post-assembly inspection (prior to shipping)
dealer pre-delivery inspection (either before hand off to customer, or after receiving from carrier).
The fact that it wasn't caught, and was left is pretty darn funny to me.
My understanding is that when these cars were being built, the emblem holes were factory punched - so if a fender needed more than the standard number of holes, then that fender assembly was assigned a different part number;
This would not only eliminate human error with badge installation, but would also speed up production in not requiring a floor worker to do an additional job.
Any misalignment of fender emblems would be from a damaged emblem, or from a replacement emblem having the holes drilled in the wrong spot.
In my opinion, anyone not taking the time to put a badge on correctly after an costly paint job is inexcusable.
But back to my understanding of factory punched emblem holes, and Paul's cited factory goof up;
This factory punching of holes for emblems was (as I've understood it) why the 1970 vs 1971 "Formula 400" emblems were different;
PMD changed practice to eliminate extra fender sub(?) assemblies.
The 1971 "Formula 400" emblems used the same holes as a standard (revised and new for 1971) "Firebird" emblem - which was also the same as the "Formula 350" & "Formula 455" emblems;
Unlike 1970, only one emblem was used per fender - so there was only one (non-Trans Am) fender assembly from 1971 forward;
unlike 1970 where there were three fenders depedning on model or options:
1) base w/I-6 & Esprit w/350; stamped for "Firebird" script emblem.
2) base w/350 & Esprit w/400; stamped for both "Firebird" script and an engine callout.
3) Formula; stamped for both "Firebird" & "Formula 400" script emblems.
For 1970 through to at least 1975, a non-TA fender only had a single badge, and which ever badge it was, it had the precise same stud spacing to accommodate that badge;
I could be wrong, but I believe that after 1975, (again on non-TA's) the only fender badge installed was a "Firebird" script badge (other callouts became decals).
That damaged(?) LeMans badge is pretty funny.
1970 Formula 400
The Following 2 Users Say Thank You to unruhjonny For This Useful Post:
Old 03-19-2026, 01:19 PM
unruhjonny's Avatar
my hunch is that either your fender was drilled for the wrong year badge, or it had the holes for the correct year badge, and the badge you used was for the wrong year.
I have understood that there are several GTO badges which look the same, but have a different application.
1970 Formula 400
Old 03-19-2026, 01:57 PM
Mr Twister's Avatar
My grandfather bought a new 79 Catalina with a Bonneville emblem on the trunk lid. Mistakes happened.
Old 03-19-2026, 02:11 PM
Keith Seymore's Avatar
In the truck plant we built vehicles that were a Chevy on one side and GMC on the other.
It's not super obvious when building up front end sheet metal in the remote areas of the plant. It doesn't become super obvious until they hit the final line.
K
'63 LeMans Convertible
'63 Grand Prix
Old 03-19-2026, 02:19 PM
Even before that, there is inspection:
At the end of each foreman's area
At the end of final line proper
At the end of short line repair or any stall repair
All of that is before it is shuttled to the shipping building.
K
'63 Grand Prix
Old 03-19-2026, 07:14 PM
gtospieg gtospieg is offline
My 67 GTO has original rear quarters. When I wanted to put rear quarter emblems on my "clone" that I'm building I measured the originals on my Real GTO, They are at different heights on each side. There happened to be another original quarter panel 67 at the body shop. The emblems on that car were also at different heights on each side. I'm thinking the quarters are stamped wrong on all of them. Maybe someday at a car show I'll take some measurements on others to see what I find.
Old 03-19-2026, 10:45 PM
I worked at a Pontiac/GMC dealer and several times we got GMC trucks with Chevrolet horn pads on the steering wheel.
Old 03-20-2026, 10:19 AM
The Champ's Avatar
My older brother had a 1979 Dodge St. Regis that the driver's side emblem said St. Regis and the passenger side said Newport, so it wasn't just GM that managed to make mistakes like this. I'm sure there were some Ford/Mercury mishaps too...
Old 03-21-2026, 10:02 AM
NeighborsComplaint's Avatar
I installed diecast 455 (Lemans) callouts on my new rocker panels. I measured the distance between the pins and the overall height and width of the emblem and laid it out on the rocker trim to drill. You’d think the pins would logically be aligned on a horizontal centerline of the emblem right? Wrong. One pin above, one below.
After I mounted the emblems and put both rocker trims back on the car, I stepped back to admire my handiwork and the emblems were running downhill! I tried to offset the holes by slotting both holes slightly to rotate the emblem and by the time the emblem was leveled, the slot peaked out from behind the numbers.
Luckily I wasn’t drilling into a fender or trunk lid! I folded the trim up like cheap Venetian blinds, threw them out and ordered a new pair of moldings.
I made a template for the next go-round by pushing the pins through cardboard and cutting around the emblem.
Triple Black 1971 GTO
Old 03-21-2026, 11:22 AM
When I bought my original paint '66 Corvette. The 427 emblem on the drivers fender was crooked from the factory. I have since adjusted it with a small file.
Old 03-22-2026, 02:24 AM
someone please correct me if I’m wrong but it’s been my understanding that Fisher did not stamp the fenders , those were done by the motor division.
The Following User Says Thank You to will slow gto For This Useful Post:
